SLK55 vs 997C4S
A)I will race both CLK55, & SLK55 next week I'm betting I'll beat both, Can you hold your water till then?
So which is it?
Why won't you answer, ricker?
..!! I guess you don't read....... all you know is how to read the Car & Driver crap......... I have to repeat myself do I......... Road & Track........ Why you keep bring up Car & Driver crap........ I bet you hang the Car & Driver test result up on the wall.........
Unfortunately, the Road & Track article of a C4S test of which you speak is not in my posession; can you scan it; I subscribe, but have not yet received the August 2006 issue. Perhaps you have?
And again unfortunately, this time for you, Car & Driver is not the only publication to have tested the SLK55 faster than the C4S. The German publication Auto Motor und Sport has tested both. Here are the results:
AMS's test of Porsche 997 C4S, 1/2006:
0 - 80 km/h 3,6 s
0 - 100 km/h 5,1 s
0 - 120 km/h 7,0 s
0 - 130 km/h 8,0 s
0 - 140 km/h 9,1 s
0 - 160 km/h 11,5 s
0 - 180 km/h 14,7 s
0 - 200 km/h 18,2 s
AMS's test of Mercedes SLK55 AMG, 4/2005:
0 - 80 km/h 3,4 s
0 - 100 km/h 4,8 s
0 - 120 km/h 6,3 s
0 - 130 km/h - s
0 - 140 km/h 8,3 s
0 - 160 km/h 10,8 s
0 - 180 km/h 13,3 s
0 - 200 km/h 16,8 s
Wow, that seems to be quite a difference there for the Benz, SL Brabus. So, I now have two magazines to your one which have tested the SLK55 faster.
And interestingly enough, they also tested a six-speed manual C6 Corvette in August 2005.
AMS's test of six-speed manual Corvette, 8/2005:
0 - 80 km/h 3,7 s
0 - 100 km/h 5,2 s
0 - 120 km/h 6,6 s
0 - 130 km/h - s
0 - 140 km/h 9,0 s
0 - 160 km/h 10,9 s
0 - 180 km/h 13,6 s
0 - 200 km/h 16,8 s
Interesting that the six speed corvette seems to have been tested slower to all speeds below 200 km/h.
And as I pointed out, thericker drives a four-speed auto.
So what does the six-speed test you quoted from Road & Track have to do with what his car will do?
I read it over the book store.......Go to any supermarket, or book store they should have them........
why do subscribe people get their mag late....
....we should get them before they hit the newstand....
As such it is going to be a drivers race. I believe that was the point that Matt was trying to get across.
Either way I'd be happy to race any of those cars.
I'd even be happy to race a turbo or Z06 ... (I'd probably lose but it would be a fun race)Btw I'd love to see the convertible numbers for the porsche and corvette. (had to throw in a last dig!)
, is they are all within .1 to .2 sec of another in the Quarter.And, FWIW, SL Brabus, I ran a std blue Carerra S in our SLK last year (2WD &
weighs a bit less = quicker than the 4S) when getting some race gas. Guess what? He got pulled by about a car length from about 10 mph (when he decided to get be a "Hero") to about 75 mph. So, we have multiple data points (including 1 real world experience to a variant of the 911 which is actually a hair quicker than its 4S bretheren). I still say the cars are pretty evenly matched but if I had to bet money on either, I'd put it on the SLK. It weighs 75 lbs less, does not suffer from 4WD parasatic drive train loss, has significantly more torque to "fight nature" as speed increases, more aggressive gearing (as Improv has correctly noted), and will never "blow a shift" (which can happen with a manual in the "heat of battle").
-Matt
-Matt
Throw in production tolerances to the mix. Cars DO NOT all produce the same rated horsepower from the factory; some produce more, others less, others right on the money. So many variables, which is why the mags *always* publish a "significant difference" factor for their test results, and that number is normally 0.5 seconds. Meaning that if two cars are within 0.5 of one another, the winner is not gonna be a foregone conclusion....unless you managed to get two drivers with *identical* skill, reaction time, shift times, etc. at the wheel, and what are the odds of that??
And skill is also a *huge* factor w/a manual tranny. It takes a lot of time, practice, and stuff you're simply born with (reflexes, reaction time) to be able to hit these times with any level of consistency, and even with an automatic, it's tricky in these high-torque beasts to always get good launches. You learn this stuff pretty quickly when you go to a track for the first time, which will learn ya that: 1) those guys who drive for the mags are pretty good drivers, and 2) there's more than a bit of skill involved in matching those times, let alone beating them, thanks to all of the aforementioned variables...
The automatic removes all of these variables except wheelspin from the launch, which gives the AMG cars a big advantage against any of their manual-transmissioned counterparts, and is also the main reason that bracket racers are almost always equipped w/ automatic transmissions. If you have two cars whose measured 1/4 times are within 0.5 of one another line up, 9/10 times the auto is gonna win on the street, simple as that. There are manual drivers out there who can nail great times with consistency, but they're about as rare as an uncooked steak.
and under braking it`ll wup any merc (slr and clk dtm not included) which have possibly the worst dive and diagonal pitch under braking of any performance car ive driven. However they are good for cruising
Braking by the Porsche was indeed better, though minutely, 152 ft. from 70 mph compared to 156 for the SLK55 (a benefit, along with less dive, of having the engine mounted in the rear), and if I was going to a proper track, I'd want the Porsche, but at the dragstrip (or on highway runs) I'd put my money on the AMG.
I'd like an answer to my questions. You ridiculed me for pointing out that Mercedes have far more agressive gearing than your car, and for my stating, accurately, that agressive gearing makes cars faster, which I showed by illustrating how it gives more torque multiplication and hence far more wheel torque. Then, you turn around in this thread and argue that your 3.15:1 is faster than a 2.73:1.
So which is it?
By 60 i had pulled so my rear bumper was just over 1/2 of a car length ahead of his front bumper...had to shut it down right away due to traffic but it was a great quick kill...
See ya Buddy.-Matt
-Matt
P.car........
One thing about the P.car all-wheel-drive that thing take off like a fu*k arrow.........
Why don't you meet us in LA next week and bring that a$$ whopin'
All in good fun there BIG talk
So is anyone gonna videotape this thing? It'd be cool if we could have a camera at each end of the run, as in the E55 vs. Cobra videos I posted (these two):
Video one: stock E55 vs. 452 rwhp Cobra
Video two: stock E55 vs. 452 rwhp Cobra: the rematch:
I'm very anxious to see thericker, in his car where shorter gearing *does* help acceleration, defeat the SLK55 and put "BUSLENGTHS" on the CLK55--cars where shorter gearing does *not* help acceleration.
Click here to read all about it:
So, *****er: since all of those "BONE STOCK" C6 A4 3:15s like yours are running 12.5's, I guess that Falco's SLK55 is running what, 12.3's or 12.4's??
http://www.caranddriver.com/roadtest...slk55-amg.html
When from that list you posted from CorvetteForum.com BONE STOCK C6 M6's reported times of 12.23 @115.58-06cgfvr w/4 other M6 C6's in the 12.40's But you wont list these times, You only Advertise that Car&Driver article a quadrillionnnnnnn times.....Your a joker anything to try to make the C6 look inferior to a heavier less powered benz
I love Mercedes also but up your meds &/or get some therapy guy.
Guess there's something to those "worthless" magazine test results after all, eh?
Hmm, *****er: looks like the results you got were in line with what the evil Car & Driver results were predicting, and you're modded, while Falco is stock!
We'll run again but it will have to wait for a while I'm having some Medical issues right now, I'm sure your all broken up to hear about that thanks no condolences are needed.
Ever thought about trying De-caff?
I don't bother racing C6's but I'd love to run a Z06.
Isn't Palmdale an 1/8 mile track for test & tune wed?
Next flying insult after this post will result in a 7 day ban.
you a bit...I'm sure you'd have done the same if it'd been me who'd gotten beat.
Seriously: best wishes, and get well soon.
