Kill Stories Discuss your exciting high speed excursions here!
Stock Z06 C6 w/BFG's 10.85 @129.50
Old Nov 9, 2006 | 04:34 PM
Thericker's Avatar
V12-Biturbo
Originally Posted by reggid
130mph seems like a high trapspeed on a stock engine
It's Stock besides mods I previously listed above stock bottom end w/364 cube engine--2005 C6 w/A4 trans = Auto 4 speed 1st is good till 65+ 2nd gear 95+ 3rd gear EZ 130+ 4th gear = FAHGIDAHBOUTIT'
Old Nov 9, 2006 | 06:23 PM
AMG_55's Avatar
mymbonline
Originally Posted by sprink49
Ed Cole was an engineer with Cadillac in the late '40's~early 50's that developed the overhead valve caddy V8 and then took the technology to Chevrolet...Duntov worked with Cole and put the 265 small block Chevy in the '55 Corvette. You know the rest of the story.
thanks
Old Nov 9, 2006 | 06:24 PM
AMG_55's Avatar
mymbonline
Originally Posted by FORZFED
no..thats right..your at 130 in 3rd..4th ends around 160ish..they say 5th goes to 198 ..and 6th is loud and pointless.
has anyone dropped in lower gears/final drive?
does anyone make them?
that would be my first mod
Old Nov 9, 2006 | 07:53 PM
Thericker's Avatar
V12-Biturbo
Yup plenty have, stock C6 m6 get 3.42's same w/Z06, C6 A4's get 2.73 or 3.15's plenty of aftermarket 3.73's 3.90's & 4.10's----Yes indeed they provide neck snapping power
Old Nov 9, 2006 | 10:20 PM
meegle's Avatar
2007 SL550, 2008 S65, Golf cart and a few non-MB vehicles
You may want to try these guys and ask for Chuck. They are Getrag rear end specialist for both C5 and C6's.
Chuck Mosello - CORVETTE DOCTOR
Corvettes of Westchester
281 North Broadway
Sleepy Hollow, N.Y. 10591
914-332-0049
Old Nov 10, 2006 | 04:34 AM
AMG_55's Avatar
mymbonline
281 North Broadway
914-332-0049
thanks, im still undecided between a z06 and a 997S, if i get a z06 i will definitely check them out
Old Nov 10, 2006 | 06:47 PM
  #32
newton22's Avatar
BMW E39
You guys have to keep in mind that he ran at -850 DA.
At -850 DA, my stock S430 would run 14s (BTW, don't laugh).
Old Nov 10, 2006 | 09:10 PM
  #33
meegle's Avatar
While the 997S is sweet, the C6Z06 is just incredible. Titanium intake valves and connecting rods along with dry sump oiling were usually only found in pro-stock type engines or a few of the exotics but NEVER on a readily available production car. Factor in the carbon fenders and special frame and it should be an easy choice.
I found a dealer who is selling them(brand new) at -$500 off MSRP. PM me if you're interested.
Old Nov 10, 2006 | 11:46 PM
  #34
AMG_55's Avatar
mymbonline
thanks, i will if i decide to get a z.
the only thing that bothers me is that i will have to spend at least 10k on it to make the interior decent and put some coilovers on it (leaf springs ).
and its also kind of wide for the canyons and there is 0 steering feel (even z06 owners admit to it)
i dunno what i want
Old Nov 11, 2006 | 06:36 AM
  #35
FORZFED's Avatar
i dunno what i want
what do you mean leaf springs?
Old Nov 11, 2006 | 02:55 PM
  #36
whoover's Avatar
'19 E63S sedan
There's no arguing that the car is a monster, but imagine if GM set their mind to really engineering into the 21st century, or even the 20th. Not only leaf springs, but pushrods? "Titanium pushrod" sounds like the punchline of a joke.
Old Nov 11, 2006 | 07:37 PM
  #37
AMG_55's Avatar
mymbonline
every mag i read, they said it had leaf springs and its horrible over mid corner bumps (there are lots of those in the canyons)
Old Nov 11, 2006 | 10:34 PM
  #38
meegle's Avatar
I believe all vettes since 1963 utilize IRS and not leaf springs.
Old Nov 11, 2006 | 11:12 PM
  #39
AMG_55's Avatar
mymbonline
from motor trend:
2007 Chevrolet Corvette Z06 Coupe Handling, Ride & Braking Standard Features
- Four-wheel ABS
- Cornering brake control
- Four disc brakes including four ventilated discs
- Electronic traction control via ABS & engine management
- Immobilizer
- Rear limited slip differential
- Stability control
- Wishbone front and rear suspension independent with stabilizer bar and leaf springs
Old Nov 11, 2006 | 11:57 PM
  #40
whoover's Avatar
'19 E63S sedan
The Corvette does indeed have four-wheel independent suspension. It's just that it uses leaf springs instead of coils.
Old Nov 12, 2006 | 12:35 AM
  #41
meegle's Avatar
from motor trend:
- Four-wheel ABS
- Immobilizer
- Stability control
Sorry about the confusion. They do have a leaf spring which is mounted transversely and serves in a different capacity than that of the older leaf spring cars that had them mounted from front to back like the early camaro's, mopars.
Old Nov 13, 2006 | 03:14 AM
  #42
AMG_55's Avatar
mymbonline
no problem, i was a little confused alredy b/c i wasnt sure 100% about it myself. i decided im going to go w/ a 997S, its a better everyday car in my opinion and from what i have read on various forums, plus its german and i wont be driving cobalt loaner cars (does chevy even give loaners )
Old Nov 14, 2006 | 11:57 PM
  #43
Juice it's Avatar
Bentley Arnage Red Label
Thats what I am thinking as well. I don't care how well you can launch a car, it doesn't explain why his trap speed is higher and 1/4 time for that matter are WAY lower than just about everyone on the planet. If your passion is drag racing and you put on drag radials to get better times who would leave the filters alone and whatever else if it would help. Doesn't make sense.
Old Nov 15, 2006 | 11:47 AM
  #44
merc655's Avatar
a few...
1. The Z06 has transverse leaf spring rear suspension. Just google a pic of the underbody and you will see it.
2. The reason that Ranger's time seems so unbelievable is because it is. He has been known to get the best times out of cars ie. new and old Z06. Look at his times for the C5 and C6 Z06s and you will see it that he is way out ahead of everyone else. Which after 52 times running his stock Z06 he got this time on DRs...
Old Nov 15, 2006 | 12:12 PM
  #45
Juice it's Avatar
I can see he is a great driver but that doesn't explain trap speeds so much greater. That part doesn't make sense.
Old Nov 15, 2006 | 03:24 PM
  #46
Zlicious's Avatar
Hooptie
Being at sea level with a negative DA and great driving will do that.
I have a Z06, and I will tell you right now that it is NOT a 129.xx mph car. On average, it is a 125 mph car.
Old Nov 15, 2006 | 06:55 PM
  #47
Juice it's Avatar
I live in Md. and can drive just fine but I don't get 4 or 5 mph more in the traps than everyone else that has an SL65.
