E55 VS MUSTANG CROSSBRED W/CHEVY 406 MOTOR
When i saw the car,i said no way am i going to beat this car....but i had accepted the callange,i was about 150 miles from home,and it was cold(19-20degrees)so i said what the hell,i am going to try it.
We lined up to do the race,and he did the burn out from hell,which scared me even more.
We too k off together with him having about 1/2 car length on me because of his 5000rpm torque converter....but as soon as we went to 2nd i went by him and got to the 1/4 about 3-4 cars ahead of him.No one could believe it,not even me.He asked if i would re run the same race next,week,and i accept,being the true sportsman that i am,and knowing that i might lose the next time around.
Next week came around,and he had his car in the shop all week,making it faster to out run me.During that time i put a stall in my car that would help me with my launch.
We lined up as before,and this time i pulled him out the hole,a the 1/8 mile he caught up and we stayed like that through the 1/4 mile with it being too close to call.Iwas not too dissapointed because i did not expect to run even that close to him.My car is a kleeman k4 with a LET tune.I need an additional 25-30 rwhp for the next race.....any suggestion?anyone?
a
And I'm going to assume you already have your spare removed and every other little tool you don't need? Run with a 1/4 tank of gas, and for the race remove your air filters for maximum air flow.
Just make sure you put em back on ASAP after the race
How much of this guy's money have you taken?? Seems kinda fishy that someone would call you out from 150 miles away.
PS. a 406 isnt a stroker... its a .030" bored over 400 block with a stock crank. A stroked 400 is in the neighborhood of 421 or 422, and a stroked 350, .030 over is a 383.
You might even notice a bit of a power increase first tank around!
*Don't forget to empty your windshield washer reservoir of fluid.
*All manuals, mats, items in trunk, trunk pad, tool kit, first aid kit in seat should be left at home too. The sun visors come off, and nobody will notice.
*I don't think your car has a spare, so no worries there.
*You can remove one (or both) of your horns.
*Get rid of your dual FMHE, and go to a single, lighter, more efficient unit.
*You can swap out the OEM battery (~70lbs) for an Optima (~45lbs) or a Braille/Odyssey unit (~12lbs)
*If you're really getting aggressive, the OEM speakers are very heavy, as is the passenger seat. The rear seat should already be gone at this point, along with the center armrest.
*Lastly, be sure and drop a deuce before your race....every pound helps !!!
https://mbworld.org/forums/w211-amg/266746-cel.html
Also, is taking off the snorkels a good idea? Sounds like your initial "breath" will be the hot air under your engine when you launch.
Since you smoked him the first time and were pretty even the second time, I would say that your "set up" is already pretty good. Maybe just work on your launch and dropping that duece
(and un-needed weight). Good luck and let us know how it goes.
