Power window motor...
http://www.grill.org/rodney/mclass/mlswitch/index.html
Any other suggestions, or does this just about cover it Thanks!
Also, for anyone who has performed the aforementioned task...on a scale of 1 to 10, how hard is the repair? The reason I ask is that I am good at taking things apart and fixing them...not so much at getting them back together.
I purchased the switch module for just under $90 (my mirror switch came apart, so I could not use the window switch repair outlined). The only problem I had was getting the wood panel out--I had to carefully pry with a screwdriver on one edge to get one of the clips released.
Riz
My time chart:
5 minutes prep time
5-7 minutes disassembly of the center console (no need to remove shift knob)
5 minutes to open switchbox and recontact the prong (with tissue insert)
5 minutes re-assembly
5 minutes testing all features (locks, front and rear windows, defrost, cig lighter)
Does anyone know the answer? I tried adjusting the plastic socket many times and it seems it works fine before on put on the black plastic cover on.
I don't mind taking it apart but I just need to diagnose the problem before I do all the work.
Thanks for the tip buddy i owed u one for this...
