Turn Signal (Indicator) Flash double speed
Old Feb 18, 2006 | 04:37 PM
Osprey's Avatar
Mercedes ML 270 & Audi TT
Post Turn Signal (Indicator) Flash double speed
I have a 2002 ML270 CDI - with an intermittent turn (signal) indicator problem. After about 5 minute driving when you indicate to turn (either direction) the turn signal flashes double speed. It is as if a bulb has blown, but all 3 bulbs are working. I have replaced the relays. Has anyone come across something like this before, Thanks.
Old Feb 18, 2006 | 04:42 PM
TheTwins's Avatar
'97 W202 C180 aut. Elegance Former : '99 W202 S500 w. keyless go, carlsson lowering kit.
If you have a towing hook on your ML, and the power for the socket back-there is on, the turn signals gets messed up if nothing is in the socket..
At least it did on my friends ML 270CDI final edition.
Hope it helped... :p
Old Feb 18, 2006 | 04:53 PM
Osprey's Avatar
I do have a tow hitch, but I have disconnected the electrical trailer connector from the wiring harness inside the car, but still get intermittent problem, Thanks.
Old Feb 22, 2006 | 08:36 AM
00ML430 Bulldog's Avatar
2000 ML430
Check for a blown bulb. check all of them.
Old Feb 22, 2006 | 09:18 AM
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
that could be it, I think that some cars do that in order to signal to the operator that a bulb is out, they dont put a lamp out bulb on the dash board so that could be your problem
Old Feb 22, 2006 | 10:47 AM
exexpat's Avatar
2001 ML320 Sport
Are you running LED bulbs anywhere by chance? That will also do it.
Old Feb 22, 2006 | 03:24 PM
55fanatic's Avatar
wait a second!!! Is the blinker fluid level low?
Old Feb 24, 2006 | 09:39 AM
Osprey's Avatar
All bulbs are working both sides - not sure about them being LED
bulbs - those fitted are as standard, Thanks
