catalytic converter
Old Jan 20, 2007 | 06:03 PM
esco7497's Avatar
Cool catalytic converter
Okay here is the deal. I have a 99 ml320 and the other day i floored it and hit a pot hole. After i shut the car off and shut it on I heard a strange noise from the undertail. My uncle who is a crack mechanic took a look at the car and told me it was the muffler. I took the vehicle to meineke and they told me it was the catalytic converter. They wanted to charge me $389.00 to cut the bad cat out and replace it with an aftermarket. Not satisfied i went for a second and third opinion but i am still not satisfied. My uncle wants to weld it but i was told not to have that done. Can anyone give me some advise and what to expect. I definitely know that it is the cat due to air coming out of it and noise coming directly from it. What is the price range and should i look around on the net for the items rather than have some mechanic give me his two cents.
Old Jan 20, 2007 | 09:19 PM
azinn's Avatar
2014 RX 350 F Sport, 2007 Scion tC, 2000 ML 430 Money Pit Finally Gone! Oh Happy Day!
Call the dealer, it might be covered under a recall they have had on catalytic converters. You are not the only person with the problem. There have been many catalytic converter failures. Might save you a few bucks. If its not covered under the recall at least you tried. My 2 cents.
Old Jan 21, 2007 | 12:51 PM
esco7497's Avatar
thank for your 2 cents i appreciate it
Old Jan 22, 2007 | 01:13 PM
fkong777's Avatar
07 GL450, 91 NSX, 12 Prius
dont call the dealer. They may just say there is no recall. Just bring the car there and ask the Service advisor regarding the CAT recall due to failed weld on the Cat. The cat recall do not expire BTW.
Old Jan 25, 2007 | 10:03 AM
runutzzzzz's Avatar
My Dealer says nope! I've got a 2003 ML500 with 99K miles! Right cat cracked!
Old Jan 25, 2007 | 12:19 PM
w163ml's Avatar
The recall is good on SOME 1998 to 2000 MY CATs and is based on your VIN #.
MB has determined that one of the two CAT suppliers for those vehicles involved did a poor job welding the seams on the CATs therefore only vehicles equipped with bad CATs (falls within a certain range of VINs) will be recalled.
Old Jan 25, 2007 | 03:16 PM
fkong777's Avatar
go to a non-chain branded muffler shop and weld in a magnaflow high flow cat for $100 installed each. I did that on my 540i. it works great.
Old Jan 25, 2007 | 04:48 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
Our '99 ML430 had its catalytic converters replaced under the national emissions law that says automobiles are covered for 8 years / 80k miles. If your ML is under 80k miles, you should be covered under that emissions law.
