halogen projectors??
Old Sep 20, 2007 | 04:51 PM
W163///AMG's Avatar
01ML55
i got a 01 ml 55, just upgraded my headlights to a halogen projector..My question is>> will my stock hid h7bulb fit the halogen prohttp://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=011&sspagename=STRK%3AME WN%3AIT&viewitem=&item=320159522817&rd=1jector??
Old Sep 21, 2007 | 10:55 AM
hanniep's Avatar
01 ML55, 91 Supra Turbo, 05 Audi S4
Did you new headlight assemblies not come with the bulbs already installed? Your stock H7 bulb is Halogen not HID, it is the low beam for your Xenon's, Did you have them re-wired by the seller to except the ML55 harness??? plug and play??? I got mine from the same seller..
Much better looking........
Old Sep 21, 2007 | 03:33 PM
W163///AMG's Avatar
01ML55
thanks for the info bro, just emailed the guy to rewire the harness for me.. The truck looks so much beter w. these headlights, cant wait to get mine..can we use our existing h7 bulbs for these projectors?? Is it really as advertised as a plug n play??thanks bro
Old Sep 21, 2007 | 08:41 PM
hanniep's Avatar
Question
holla when you get them,. if you need it,. I can give you a few tips on the install.
Old Sep 26, 2007 | 09:33 PM
myanow's Avatar
2000 ML320
I just order a set for my ML320 from the same ebay store. Are these easy to install? Any tips?
Thanks,
Marcelo
Old Sep 26, 2007 | 10:39 PM
hanniep's Avatar
Very easy to install, 3 bolts to remove, Take notice of your headlight adjustment (adjustment/removal screws) behind headlight cladding right above my headlight washers,...and make sure the new ones are adjusted correctly,..I did not do this and had to re-adjust mine several times to get them correct and not blind oncoming drivers. LOL!! ..Good luck, PM me if I can help...
Old Sep 27, 2007 | 10:36 AM
myanow's Avatar
2000 ML320
Thanks for the tips! BTW what type/brand of bulbs does they come with? I was looking to buy the new Philips CrystalVision Ultra bulbs to install with the new headlights.
http://www.nam.lighting.philips.com/...stalvision.php
Old Sep 27, 2007 | 06:56 PM
hanniep's Avatar
They came with GE standard H7 bulbs, I use PIAA Xtreme white, cool blue color....
Old Sep 28, 2007 | 07:51 PM
W163///AMG's Avatar
01ML55
hanniep>> have ever change the foglight bulbs?? are they easy to change, was thinking of changing mine to color yellow. which bulb is it?? correct me if im wrong but isnt the h3 fogs??
Old Sep 28, 2007 | 09:44 PM
myanow's Avatar
2000 ML320
My current headlights don't have front fog lamps (I do have the wiring and the switch working) I got Philips CrystalVision ULTRA (Super White) H1/H7/H3
The fog ones are H3. You can see all bulbs on http://www.suvlights.com/information.php?info_id=17
Can't wait to get the new headlights!
Marcelo
Old Sep 29, 2007 | 11:23 AM
hanniep's Avatar
Changing mine today. to PIAA super white it's a H3 bulb, easy too, just pry off the front cover (be careful) and for the fog light assembly twist off the black cover and the whole thing comes out, reverse proceedure to put back on...
