Brake Question
Old Jan 29, 2003 | 11:12 AM
ML_captain's Avatar
ML
Question Brake Question
Hi All~
I have a 2000 ML320. It's about time to get the brake pads changed (first time). Got the pads from internet for about $170 (front and rear pads + sensors).
One quick question.... do I need to have the rotors re-surfaced when changing the pads? I have heard someone said that MB rotors don't need to be re-surfaced. Is this correct?
Many thanks in advance!!
Old Jan 29, 2003 | 12:10 PM
rskinner's Avatar
2001 C240/2000 ML320
I replaced my fronts w/o resurfacing the rotors. YMMV
Old Jan 29, 2003 | 05:46 PM
ML_captain's Avatar
ML
rskinner
Thank you for the reply. I found the holes on the pads for the brake sensor. Could you please tell me where you bought those "metal rings" to secure the sensors to the pads?
Thanks a bunch.
Old Feb 3, 2003 | 12:14 PM
rskinner's Avatar
I don't recall a metal ring, but it has been about a year since I did it. Sorry.
Old Feb 3, 2003 | 01:07 PM
buddhatikigod's Avatar
99 Ml 320
Is it easy to change the pads, or just like a regular car maybe? Im right about to have a friend of mine whos more profriceint with things like this then i am, anything we should know?
Thanks,
Steve
Old Feb 3, 2003 | 04:30 PM
Some Pete Guy's Avatar
'82 turbo yugo
Thanks,
Steve
It's easy:
http://www.petefagerlin.com/ML/brakes.htm
Old Feb 3, 2003 | 08:25 PM
ML_captain's Avatar
ML
Great info! Thanks Pete and Rskinner!
Old Feb 4, 2003 | 11:14 AM
99 Ml 320
sensor in each pad?
hey all, again. im buying some brake pad and rotors online from ebay. i bought the rotors 4 for $200 even, and im right about to get the pads, 175 for 4. I asked him about the sensors he said he would (he being the guy that sold me the pads and the rotors) give me 2 for $5.00. I said i was doing all four wheels he said you only need 1 sensor for the front, and 1 for the back.
Is this true? I thought you needed 1 for each one.
Steve
Old Feb 4, 2003 | 12:57 PM
'82 turbo yugo
Re: sensor in each pad?
Steve
One for each wheel is how they come from the factory.
You want one per wheel because if a piston sticks on a wheel that doesn't have a sensor you are SOL.
