Help - 2000 ML320 stops, then cranks but does not start anymore
Old Aug 26, 2009 | 04:41 PM
intrinsico's Avatar
2005 E320, 2004 C240 4Matic, 2001 S430
Hello everyone,
I have a 2000 Mercedes ML320 that has a weird problem: it runs for a while, then it stops (randomly, either at idle or while in motion) and then it cranks but does not start anymore unless left for 15-20 minutes...
Here's what I've done so far:
- swapped the gas pump relay with no luck
- took out the fuel filter and blew through it, seems not to be stuck
- flushed out the gas pump by jumping the K3 relay
- now, here's the interesting part - I noticed that after the truck stops, there is no more power at the plug that powers the gas pump. This seems to be the real problem and have no idea why that is. Seems like something is heating up and cutting power... Could it be the relay (again, swapped it with others a couple of times)? The board that it plugs into?
Any help would be greatly appreciated.
Thank you!
Old Aug 26, 2009 | 06:07 PM
azinn's Avatar
2014 RX 350 F Sport, 2007 Scion tC, 2000 ML 430 Money Pit Finally Gone! Oh Happy Day!
My best guess would be a failing CPS (crank position sensor).
Old Aug 26, 2009 | 06:09 PM
intrinsico's Avatar
Interesting, and this would also make it stop while running?
Old Aug 26, 2009 | 06:18 PM
azinn's Avatar
Yes, they fail when hot. Will let you restart when cooled off. Common problem with the ML.
Old Aug 26, 2009 | 06:23 PM
azinn's Avatar
Plenty of stories here on CPS failures -> http://www.benzworld.org/forums/sear...archid=4784475
Old Aug 27, 2009 | 03:49 PM
intrinsico's Avatar
Picking up a CPS today, will report back. Thanks guys!
Old Aug 28, 2009 | 08:28 AM
intrinsico's Avatar
Replaced the CPS and that did it! Thank you everyone!
Old Sep 4, 2013 | 01:31 AM
JJerry1's Avatar
ML320
I have the same problem with the same Automobile. Changed CPS, Fuel Pump, Fuel Filter and still have the same problem.
Old Nov 26, 2013 | 08:53 AM
Donttrinh's Avatar
Ml320
Hello JJ.
Did you get your ML run? I have same problem. Need some helps only car we got.
Thanks.
Old Nov 27, 2013 | 03:12 PM
art_arev's Avatar
2003 ML55,2007 ML63
People... in order to get help please tell us about your problems in details. As mush details as possible. Past..present..etc. Details
Old Dec 2, 2013 | 03:57 PM
jdlgreen's Avatar
ml320, ml320, ml350, ml430
Starting problems
We had the exact same problem on our 99 320.
After much searching, it ended up being the crankshaft position sensor, (or whatever the technical name is).
It only sensed movement intermittently, so did not provide spark and gas.
Changed it out and has run great for 7 years.
John
Old Dec 16, 2013 | 07:44 PM
rantee's Avatar
1999 C230 Kompressor Sport, 2002 CLK320 Sport, 2003 ML320 Sport, 2004 BMW R1150R Rockster
crank shaft position sensor, easy fix
