Hood Stay Replacement
Old Oct 7, 2012 | 12:36 AM
2.7Tallroader's Avatar
W211
On a 1999 ML320 with the prop rod to keep the hood open, has anyone replaced this successfully with a pneumatic hood strut? If so, do you have part numbers for the conversion?
Old Oct 7, 2012 | 04:46 PM
Mike's ML's Avatar
1990 190E 2.6, ... 1998 ML320, 2005 ML500SE
My 98 ML has the hood prop rod and my 05 ML has the strut. I very much prefer the 98's prop rod because I can prop the hood in the vertical position which cannot be done with the strut unless you change the strut attachment position which is hard to do. Also too much opportunity for damage to the hood if the position is changed and someone tries to close the hood. I want to change my 05 hood to the prop rod but I keep forgetting to find used rod from a salvage yard. Thanks for reminding me.
Mike
Old Oct 7, 2012 | 07:05 PM
W211
you're welcome, Mike. If you want we can swap. I'm looking to replace the hood prop in my ML to a gas strut. Let me know.
Old Oct 8, 2012 | 10:17 AM
Mike's ML's Avatar
I would want to keep the original setup for resale value. I want to add the hood prop and just remove the two struts but make no major changes. I'm not sure but you may need new hood hinges along with the struts and attachment points. I do not want to remove my hood hinges. That's just asking for trouble.
Sorry.
Mike
Old Oct 8, 2012 | 11:55 AM
W211
Thanks for you reply, Mike.
Old Oct 11, 2012 | 06:26 PM
W211
Anyone have a part number for the pneumatic props and hinge brackets?
Old Oct 11, 2012 | 09:09 PM
Mike's ML's Avatar
Here are the part numbers for the hood strut assembly.
As best that I can tell the "Up to ident no." for the hinges (#20) are for the hood support #31, 35 & 38 and the "As of ident no." for the hinges (#20) are for the strut (spring) #32.
Mike
Old Oct 12, 2012 | 12:26 PM
W211
Thanks, Mike.
Old Oct 13, 2012 | 06:49 PM
xxGenericSNxx's Avatar
99 ML430, 01 CLK55, 07 R63, 15 E63 Wagon
I did the swap on my 99 ML430 from pop rod to strut. I don't have the part numbers but I will tell you the process was very straight forward. Bought the brackets from the dealer (they ran a 2000 ML55 VIN) and got all the part numbers from there. I did this back in 2000 and cost about $200 in parts and installed myself. Good luck! It's so convenient to have the struts hold it open rather than the old school pop rod.
Old Oct 13, 2012 | 06:53 PM
W211
Great. I'll have the parts sorted out in the MB parts department. Thank you.
Old Dec 17, 2013 | 12:31 PM
Bezalel's Avatar
ML320 W163 2000
Just to add a comment to this old thread - the gas struts on my 2000 ML320 hood are on the way out (hard on the back of your head when the hood falls down!), so I just stick a bit of wood in as an extra precaution until I get them fixed (not a priority yet!).
