stereo dash kit?
Old Jan 16, 2004 | 05:00 PM
90gtx's Avatar
ml320
stereo dash kit?
i want to change my stereo in my 2000 ml320 but I cant find a kit to fill in the extra space. can some one lead me there. Is there aslo a wiring harness. Where is the factory amp located?
Old Jan 16, 2004 | 05:07 PM
Benza's Avatar
ML 320
What about adding this Radio:
Rosen R 6500
I just installed it in my H2
Old Jan 16, 2004 | 05:08 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
goto www.crutchfield.com and put in your vehicle/model/year and it should give you a list of stereo parts for your ML (speakers, decks, accessories, etc)
-G-
Old Jan 16, 2004 | 05:13 PM
90gtx's Avatar
ml320
They have nothing for my truck is there anything else?
Old Jan 16, 2004 | 11:14 PM
amb9800's Avatar
2002 ML320
Any 2-DIN size unit with compatible wiring should work - there are a number of options - I've seen MLs with Clarion radios and a bunch of other kinds - just check up on Google. BTW, you'll lose use of the CD-Changer, if you have it, because it's connected to the MCS through MB's fiber-optic audio system.
Old Jan 17, 2004 | 02:35 AM
Kar don's Avatar
Mercedes-Benz
what year is your ML? if it is a 2000 i am interested in your stock head unit.
Old Jan 23, 2004 | 11:01 AM
zeke320's Avatar
double din
You should be able to order the storage box that comes with the standard headunits on any ML from your dealer, once you install this box, you will be able to install any standard din stereo. If you have problem identifying part for box, let me know and I will post a picture of my install.
Old May 5, 2011 | 06:48 PM
jbgibso2's Avatar
2001 ML55 AMG
Double Din Stereo Dash Kit for 2001 ML55
I need help! I've seen pictures of a regular double din receiver in place of the stock doubledin nav unit with a dash kit around it, but I cant find one anywhere online. Can anybody help!? Thanks!
Old May 17, 2011 | 11:18 PM
athus3's Avatar
06_ML350; 04_E320_4M
To determine what type of fascia you need, go to eBay, have a look at items such as fascia w163 or fascia kit M class, etc., then narrow it down to your model year. Stick with Connects2, Autoleads, etc.
I used for my 02ML320 retrofit [Kenwood DD 7120] a Kenwood cage & fascia with Metra wireharness adaptors. For my 04E320 [Kenwood DD 8120] I used a Connects2 cage and fascia kit with quick wirring connectors.
Old May 18, 2011 | 08:17 AM
jbgibso2's Avatar
2001 ML55 AMG
Thanks! I'll try that for the wire harness bc I've found a dash kit at incarmusic.co.uk. but they didn't have wires to keep the nose amp with factory speakers. Thanks for the help!
Old Aug 16, 2013 | 09:26 AM
pouyate's Avatar
c
Dash installation kit
HI
Does anyone know if could change my deck in my 2010 C250? I've been looking all over for a dash kit that fits my car but I could not find anything!!
Old Nov 7, 2020 | 08:41 AM
luciansandu's Avatar
2011 ml350 bluetec
My advice is to avoid buying one of the android devices. For example, the one from Avin. I threw $ 500 out the window, after a little over a year the screen went white and their response was that it was out of warranty, they have nothing to do. However, the quality of the audio signal is poor on these devices, as well as the reception of radio programs, so if someone wants to upgrade to think seriously about buying a device made by a reputable company.
