add oil between service
anyone here get low on oil between services? Seems odd that this is the only car we've owned that needs to add oil between service. Once every few months, that little oil light will flash for a few seconds then go away. When i check it, the oil level is down to the minimum and gotta add a quart of syn formula.
I just think it's a little strange for it to be eating oil like that...my 94 engine with high mileage doesn't even need adding between oil changes...
-G-
BTW, they've done a oil consumption test and it showed it's within spec of MB.
My '99 C43 (same base motor) had tons of gasket leaks by the time it hit 100,000 miles, none were life threatening.
Warranty almost up anyway, and this one's gotta go before that happens, so haven't been too worried about it.
Now I'm holding my breath on the harmonic balancer.
hey all,
-G-
2002 C32 Black
1998 ML320 Black
Same exact problem on my 1998 ML320. And it runs through brakes just as quickly :-(
2002 C32 Black
1998 ML320 Black
Yes, the ML eats brakes like there's no tomorrow. Front pads at 20k, rotors and pads at 32k, rear pads at 33k, rear pads and rotors at 50k. That's a little too much I think...
I also agree with the 'eating' brakes. I like how it performs but not the replacement. I had the fronts repaced 22k ago and am getting the flashing light - perhaps it is the rears.
Has anyone found replacement pads that last longer, still give good performance and are perhaps a bit cleaner? What a wish list!
