ML 500 HEATED SEATS NOT WORKING
Old Jan 17, 2016 | 04:56 PM
S430LUCKDRAGON's Avatar
2003 S 500 4 MATIC , 2001 S 430 , 2003 ML 500
Its weird my heated seats are not working and the light is just flashing on the heated seat buttons when i press them ! This started yesterday when i gave my friend a jump start and now my coolant light is on and flashing every minute or so .
I checked my heated seats 20 amp fuse under the hood and the fuse was ok and its getting power . Are there any other fuse boxes in this vehicle besides the one under the hood and the one in the passenger side foot well ?
Are there any relays i should check ? Thanks in advance for any advice
Old Jan 19, 2016 | 04:54 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
I am assuming you are referring to the ML500, which has a 100 amp fuse attached to the positive battery cable (GREEN arrow).
You will see that it is blown because of incorrect jumping procedure.
Old Jan 20, 2016 | 09:36 PM
Thank you guys both so much it was the 100 amp fuse dundee had mentioned , i replaced it and it seems to have cleared up both of the issues
Old Dec 3, 2018 | 11:05 AM
fvlage's Avatar
2003 Mercedes ML 500
help
Where did you source the fuse I looked everywhere the only thing i can find is pictures of it on this forum
Old Dec 3, 2018 | 11:23 AM
Please UPDATE YOUR PROFILE in USER CP to include the year of you ML and where you live so I can give you the correct part #..
Old Dec 3, 2018 | 11:59 AM
fvlage's Avatar
Ok I think I got it if not i have 2003 Mercedes ML500 and I live in North Carolina
Old Dec 3, 2018 | 12:29 PM
Excellent.
You can only buy this fuse (100 amp) from the dealer and the nut must also be purchased as they break when removed.
