Help. All warning lights stay on after key removed & wont start
Old Aug 23, 2017 | 11:18 PM
narbo's Avatar
2003 ML350. W163
So I washed my 2003 ml350 with a Garden hose. Etc. drove 10 miles parked, restarted. Drove 5 min. Parked. Drove 2 min. Parked. Restarted fine. After 2 min. Noticed the car turned off. When I tried to restart. All the warning lights on the dash came on and car wouldn't even crank. I took the key out and the warning lights stay on. It won't turn off until I disconnect the battery. Then the doors unlock via remote and lock alarm works to. Once I put the key in pos 2. The lights all come on hazards blink and vent starts blowing. I can't connect the Obd scanner ( generic ). It says vehicle not responding. The key won't lock or unlock the car until I disconnect the battery
I have Replaced relay 12 but same issue occurs.
Any help would be appreciated.
**** correction to title. Won't crank. *****
Old Aug 25, 2017 | 06:36 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Did you only wash the exterior with the hood closed?
Old Aug 25, 2017 | 03:01 PM
narbo's Avatar
2003 ML350. W163
Yes Hood closed.
it was washed and sat for an hour before I started driving.. the engine bay was dry. i did have some leaves in the hood / wiper area.. but no visable water in the interior
Old Aug 28, 2017 | 12:55 PM
narbo's Avatar
2003 ML350. W163
CPS was repalced and now car cranks, BUT still not 100%
It cranked and started.. the strange thing is when I turn the key to position 2 the speedometer needle vibrates until the car turns on . also all the other gauges stay off for a good 30 sec after start and then become active.
any thoughts?
Old Aug 29, 2017 | 09:47 AM
Remove the Instrument Cluster and its connector. Then try to replicate the problem and see if the problem still exists.
File Type: pdf
Old Sep 5, 2017 | 06:17 PM
narbo's Avatar
2003 ML350. W163
So it turns out, it was the Crank position sensor.
i replaced it and it started right up... the only weird thing is that it takes a good 30 secs, for the gauges to activate ( Fuel and RPM ) and the speedometer shakes at startup.. and a weird ticking noise.
-Nick
Old Sep 6, 2017 | 06:36 AM
With the hood closed water cannot effect the Crank Sensor.
Old Oct 11, 2017 | 08:52 PM
narbo's Avatar
2003 ML350. W163
SO its been running fine for the last few days.. and today it turned off again while driving.. and i couldn't get it started. I did not wash it this time... so its definitely not the CPS. which i replaced.
I am going to try to remove the cluster and see if that does anything
Old Oct 12, 2017 | 06:34 AM
Removing the I.C. will do noting at this point. The problem does not occur often enough.
It's time to have the codes read with a professional grade scanner, not a code reader.
