torsion bar
Old May 1, 2004 | 01:38 AM
pointman's Avatar
a car that can't do the throttle reset.
torsion bar
my ml has been making some noises from the torsion bar. i brought it to the attention of my sa. he later let me know that my "support bracket" was broken. it was fine for a few days...but now its back!?! any ideas?
Old May 1, 2004 | 11:47 AM
mbtech208's Avatar
1997 Toyota Tacoma 4x4
Re: torsion bar
There's a shim between the torsion bar and the frame that wears through and makes creaking noises. Maybe they didn't replace those, or just did one side.
Old May 1, 2004 | 12:00 PM
pointman's Avatar
mbtech, yes they said that they only replaced one side...but its possible for the other side to go bad in a matter of days? im just worried that they are going to blame my lowered susspension.
Old May 4, 2004 | 12:49 AM
mdstran's Avatar
ML 430
i have the same problem too i lube it with silicon lubricant but it came back in a few days is there a part number for the parts that needs to be replace and how difficult the job to be done.
Old May 25, 2004 | 02:53 PM
andaya's Avatar
99 ML 430
Thumbs up Quick fix...here's the link
I had this problem for the longest time, and finally fixed it. good luck!
Hope you didn't pay the guy... and you if you did, I'm sorry for posting it to late.
http://www.4x4abc.com/ML320/ml320_torsions.html
Old May 25, 2004 | 03:52 PM
pointman's Avatar
thanks andaya for posting it. ive already been there... and sprayed the bushing...no help. any other suggestions? thanks
Old May 27, 2004 | 12:51 AM
pointman's Avatar
picked up my ml today...noise is gone!!!...for now, hopefully it will stay that way. i told them what you suggested mbtech..heres what they decided to do...
clean and lube all mating surfaces
replace left rear mounting bracket
lube right side mounting bracket
what do you think...was what needed to be done..done? or should i expect to have to go back again...like the last time they supposedly fixed it? thanks
Old May 27, 2004 | 01:06 AM
mbtech208's Avatar
Only you'll be able to answer that. If the noise comes back, it wasn't done right.
Old May 27, 2004 | 01:19 AM
pointman's Avatar
thanks for all the help mbtech. much appreciated.
