Help...wife left sunroof open...rained all night!
Old May 18, 2004 | 09:56 AM
Driver55er's Avatar
w210 e55
And damn it poured last night!
I was hoping all I needed to do was dry it out. In general it seems to be ok. It starts fine, but, the truck's shift lever won't operate. Is there a lock out that I need to reset somewhere? Or did it just get wet in the consol? Has any one else had this issue? Can I hope it will dry out in the sun and be ok.
It will be fun with the wet vac when I get home.
Any input? Any jokes?
I'm fixing a hole where the rain gets in.....
Old May 18, 2004 | 09:59 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
I'm guessing the water got into the shifter console...that thing is electronic, so it could have shorted it out (the locking mechanism that releases when you step on the brake)
Try letting it dry out for a few days.
My mother did that with our Audi once...left the sunroof open and in the morning, there were two big puddles of water in the front two seats :p Though, the tranny still worked (mechanical though, not electronic)
good luck!
Old May 18, 2004 | 10:04 AM
pointman's Avatar
a car that can't do the throttle reset.
easy fix for the shifter. look at the bottom of the shifter selector. right underneath the "D" youll see a empty slot, push down on it with a pen and then shift the lever...it should work fine now.
Old May 18, 2004 | 10:36 AM
Swiss Nick's Avatar
ML 270 CDI 2002
Failing that, fill the enitre thing with water and have the first ML fish tank.
Old May 18, 2004 | 03:23 PM
Driver55er's Avatar
w210 e55
How do you get out of LIMP mode?
Old May 19, 2004 | 12:50 AM
pointman's Avatar
you dont, you go to the dealer.
Old May 19, 2004 | 01:00 AM
mbtech208's Avatar
1997 Toyota Tacoma 4x4
I wouldn't be completely surprised if you need a new ESM (Electronic Selector Module), also known as the shifter. It ain't gonna be cheap.
Old May 19, 2004 | 09:50 AM
Driver55er's Avatar
w210 e55
Dave,
Will the shifter short out pretty easily? Will that come up on a scan if it is toast or is it a replace to see if it is broken situation?
PS Do you know the proceedure for headliner removal in a w210 e series? I have a nasty rattle I'm trying to fix.
Old May 19, 2004 | 12:05 PM
mbtech208's Avatar
Dave,
The shifter will short out very easily if any liquid gets into it. People spill drinks in them all the time. If it's shorted out, various fault codes will appear when the laptop is hooked up to it. But it's such a common thing, we know that if liquid got into the shifter, it needs a new one.
As far as the headliner, just take everything out that touches the headliner (A, B, and C-pillars, grab handles, sunvisors and clips, overhead control panel, rear dome light). It's hard to walk someone through it without actually being there to show you.
Old May 19, 2004 | 12:37 PM
drummerboy's Avatar
Re: Help...wife left sunroof open...rained all night!
I could joke about it, but I won't....I'm sure you've thought of lots of them!!
]Originally posted by mbteach208
Thanks for the Headsup.....Never thought about spills over the Shifter!
]Originally posted by ahopeter
Interesting!!...Gonna see what that thing is!...Thanks!
Old May 19, 2004 | 12:39 PM
mbtech208's Avatar
Re: Re: Help...wife left sunroof open...rained all night!
If your ML is older than a 2000, it doesn't have the manual shift release. Only vehicles with the Touch Shift have that, and even then, not all of them have it (S and CL-Class).
Old May 19, 2004 | 03:54 PM
pointman's Avatar
oh! didnt realize it was a 99, sorry, like mbtech said only for the touchshifts.
Old May 20, 2004 | 03:31 PM
drummerboy's Avatar
Re: Re: Re: Help...wife left sunroof open...rained all night!
Thanks!.......Looked, didnt see anything.
Old May 20, 2004 | 05:58 PM
JimB's Avatar
2000 ML320/'03 C320WZ
Smile ok my joke
i think it,s time to get a new wife
Old May 21, 2004 | 04:17 PM
Driver55er's Avatar
w210 e55
Wife's a keeper but it may give me a reason to trade the beast in ;-).
Good news!!! The car dried out and after disconnecting the battery for a while things reset and everthing works!!
Now all I need are a few good and sunny days to realllllly dry the beast out.
Thanks for all the help with the shifter release and other info you cats are alright!
Old May 21, 2004 | 04:57 PM
pointman's Avatar
