ML320 Vibrates on slow turning.
Old May 18, 2018 | 05:56 PM
raranas85's Avatar
99' ML320
Hello I am new member to this website, but have used this these forums to help fix my ML320. I am having an issue with my car when i am slow turning left or right. Its more severe on the left side of the vehicle. Reading previous forums, i changed out the CV joints both sides, Inner/outer tie rods both sides and replaced the rubber bushings. My lower ball joints has no signs of wear and have done the 6/12 and 3/9 wiggles and seams pretty solid. I still need to replace my rear upper control arms and break/rotor soon, but i dont think that has anything to do with the rattling and vibrations. Does anyone else have any suggestions?
Old May 19, 2018 | 03:17 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
98-99 ML's always had an issue with the Transfer Case ratio. Start by changing the T-case fluid
Buy 2 qts. of any fluid listed and pump in 1 1/2 qts. capacity used.
Old May 22, 2018 | 01:23 PM
raranas85's Avatar
99' ML320
[QUOTE=Maj. Dundee;7457744]
Buy 2 qts. of any fluid listed and pump in 1 1/2 qts. capacity used.[/QUOTE
So i changed the Transfer Case fluid and differential fluid and i am still getting the rough, vibrating when slow turning. Cars runs a lot smoother though after the fluid changes, but still has the same issue.
Old May 22, 2018 | 02:50 PM
Then you have to get a new or used one or live with it.
Post your full vin # and I will supply you with the part number.
Old May 22, 2018 | 05:20 PM
raranas85's Avatar
99' ML320
Will there by any major consequences if I just let it be and not repair or replace the transfer case? I’m sure that part is expensive and I am not sure how to do that myself. I’ve seen videos but looks too complicated for my knowledge.
Old May 23, 2018 | 03:34 AM
I'm assuming that you recently bought this truck and you bought it with this problem.
You didn't post your vin number, but as you can see the T-case has been replaced twice.
Any repair requires a lift, so you had better seek professional help.
Old May 23, 2018 | 06:12 PM
raranas85's Avatar
99' ML320
Here is my Vin# 4JGAB54E9XA069433
Old May 24, 2018 | 12:09 AM
Here is the T-case according to your vin #.
