Brakes, when they need replacement?
but if you really want to..our sponsor, good old tirerack has some really good deals. you can also checkout brakeworld.com
My brakes squeal on the ML very lightly now when i push the pedal down a certain distance. The brake pad wear light has not come on yet tho. The brakes were last changed at the dealership new rotors and pads all around @ around 19k miles. The truck now has 54.5k miles and stops smoothly still. There is a groove in the front drivers side rotor but the car still stops fine. Should i change the brakes? And if so where should i get the new parts?
OK, I just looked at your profile... 1999 ML320. I think you should probably check. There are two possibilities which could occur that would cause the replacement light to not illuminate. You should not RELY on the light, it should just serve as one indicator.
1) when the brakes were replaced, sensors were not installed. My CLK55 has no sensors on the back brakes, so relying on the indicator would be pointless
2) your pads may wear at an uneven rate, and only have one sensor installed. My ML430 had one pad sensor installed on the outboard pad on the right rear, and when I checked it the inside pad was down to almost metal while the outside pad was not to the sensor yet. We just did my friend's C36 brakes and he has ONE SENSOR for ALL FOUR pads in the back.
You could always take it to a dealer for a "free inspection" and then change them yourself.
-s-
If you are not sure, get someone to check them out, better safe than sorry!!!
a slight squeel is normal...I wouldn't worry about it. It's when it's screeching metal on metal noise pops up, then I'd have them check it out. Squeeling could be caused by weather, humidity, crap on the brakes, etc...this is NE
:pNo worries
unnecessary to change... after the light, you still have plenty of time to change.
