In limp mode. Obd scanner showing code P0705 and P0105.
Old Mar 8, 2021 | 06:03 PM
Bangingbabe's Avatar
2001 ML 320
I recently purchased a 2001 Ml 320. Days after buying it almost all dash lights lit up, abs,esp,cel,srs. After checking codes with obd scanner I replaced manifold absolute pressure sensor and replaced shifter and checked tcm for fluid in passenger side floorboard (was none). Wiring all looks okay. Still in limp mode. Going to change O ring today and clean mas to check all the bases. Any advice or suggestions would be appreciated. Thanks
Old Mar 8, 2021 | 09:33 PM
chassis's Avatar
2017 GLE350 4MATIC
Time to change the battery? If it's over 3-4 years old, it's an easy change and might be the root cause.
Old Mar 9, 2021 | 05:42 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
This problem has nothing to do with a battery.
For code P0105, simply delete the code in the ECM.
For code P0705 you must delete the codes in the ECM & the ETC Trans. Module. If your code reader is unable to read codes in the ETC, it will always remain in in Limp Mode.
Old Mar 9, 2021 | 04:04 PM
2001 ML 320
I recently changed the battery so i dont think that was the problem.
Old May 27, 2021 | 05:40 PM
fma01709's Avatar
Mercedez Benz c240 2002, color=Silver, Gasoline
Hello,
I have a similar issue C240 and I am getting P0705? I replaced the conductor plate, but still the same issue!!
How do you delete the code? is that what is causing it?
Old May 28, 2021 | 04:52 AM
You must delete the code with your own scanner or someone else's scanner. After that, the selector range sensor must be coded.
Old May 28, 2021 | 12:22 PM
fma01709's Avatar
Thank you for your input. This does apply to C240 2002 as well right? I do not have such a scanner to perform that task, so I have to take it to a repair show.
In some videos, they stated that there is no need to reprogram! Thank you again for the reply
Old May 29, 2021 | 04:40 AM
These trans. are basically all the same. Please read step 10 in the PDF.
Old May 29, 2021 | 04:48 AM
Please update your profile to include the year and model, is it gas, CDI or Blue and the country you live in.
