what do you think?
GPS
Grill Guard
Fog Ligths
Running boards/side steps
Spoiler
Mud flaps
etc.
They would all impact the price of the vehicle...you should consider those while haggling..
You want to check on two major things on this vehicle before you make the plunge.
1. At 89K its post the emissions warranty (8 years/80K miles)...were the catalytic converters (CATs)replaced on it? Most 00 MLs (like mine 00 Ml320 -76K so far) have had their CATs replaced because of a faulty weld on them. If the CATs haven't been replaced...be preapred for up to $2400-$3000 to have them fixed, if they crack.
2. What's the state of the harmonic balancer...if its wobbly or showing signs of wear, I would insist on having it replaced. That's another potential $2-3K repair item, if it breaks while running.
Apart from that, be prepared for the following things.
1. Aux Fan wiring harness (if it hasn't been replaced so far) ($300)
2. A couple of window switches/locks($200-500)
3. Motor mounts - subjective to driving...my lasted for about 60K..before needing to be replaced...I am an occassional off roader though..($300)
4. Mass Air Flow Sensor ($550)
etc.
Good luck with your purchase. I am still more than satisfied with my 00 320, inspite of all these glitches that I went through, some under warranty, some post warranty.
I too would advice on buying the warranty...
That said, I too managed to take the MAF off in just 5 minutes, clean the sensor wire and plug it back in. My symptoms were all gone.
Its been 15K miles since I cleaned the MAF, its been working like a charm. I read at a website, that it was not a bad idea to clean the MAF every 20K-30K miles...just need to be careful about not damaging the sensor wire, otherwise its toast..
As I said on the other forum - too old, too many miles, too many problems too much $$$
But going by your posts you seeem to have convinced yourself it's a good deal - so on that basis, keep your fingers crossed and enjoy your ML.
BTW I'd willingly sell you my '00 ML430 with only 68,000 miles, unmarked condx, new tires / brakes all round and practically all known problems areas fixed / replaced for sub $15,000.
Much better private deals to be had.
