Static on the HK sound system
Old Sep 8, 2005 | 12:30 PM
gsrjc's Avatar
2011 GLK350, 2010 ML350, 2008 C63 AMG
i just started my ML350 after not driving it for a couple of days. well i noticed this morning that my HK sound system had tons of static in it while i was listening to the radio, so i changed stations and same thing. so i decided to change to the cd changer and listen to see if the static was still there. and yes it was, than i played with the fader, the different sound settings that come with the HK, and the damn static was still there. i only have 600 miles so i plan on complaining about the static when i go back for my 1000 mile checkup. pretty disappointed that this is happening. i thought i saw a post before about the sound system, but i couldn't find it.
any ideas? loose ground somewhere? blown speakers?
Old Sep 8, 2005 | 03:47 PM
Flipsonic's Avatar
2006 ML350
Turn the engine off and turn it back on. Hope that helps.
Old Sep 20, 2005 | 11:25 PM
gsrjc's Avatar
yup, that fixed the problem. do you think that it static was because the car isn't completely grounded. i found this on the internet and wondering if it would make the car run better? what do people think.
www.groundfusion.com
Old Sep 20, 2005 | 11:46 PM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Audio noise
Gropund issues do not go away by turrning the ignition off and then on again. Nice tryk, but I think it is osme other issue.
Old Sep 21, 2005 | 01:23 AM
MB Fanatic's Avatar
4 wheels
The famous AUdio Gateway problem that plagued many E class owners of the HK system. Simple fix, just take it to your dealer.
Old Nov 9, 2006 | 09:50 PM
Alabaster's Avatar
2006 ML350
Unhappy Static from sound system
This is an old thread, but I recently re-experienced the problem too. The dealer replaced the COMAND center 6 months ago, but just yesterday this problem came back for me. Has anyone else experienced this static? When it happens nothing comes in clear, not CD or Radio. Turning the car off and restarting takes care of it, but seems like an odd fix. Is possible that I received two bad COMAND units?
Old Nov 13, 2006 | 06:56 PM
Petmerctech's Avatar
Have the dealer perform software updates on the COMAND unit.
Old Nov 13, 2006 | 07:28 PM
Tejas's Avatar
2008 ML320 CDI
I had the same problem in my ML350. I found if I turned off the stereo and then rotated the volume control back an forth i.e. 360 degree turns. This fixed the problem. I normally use the volume controls on the steering wheel. Since I've done the rotate thing I've not seen the problem. My guess is a dirty variable resistor.
T.
Old Nov 14, 2006 | 09:42 AM
alan s's Avatar
I have a similar static problem on occasion. It goes away by itself, but the static is very loud and I am unable to hear the music/radio when it occurs. The dealer said the amplifier needs to be replaced. I have yet to take it in, but this appears to be a well known issue.
Old Nov 14, 2006 | 01:03 PM
dante&david's Avatar
From 2006 ML 320 CDI - from 2009 Audi Q5 S-Line 3.0 TDI DSG - from 2011 Range Rover Sport TDV6 HSE
Sorry, what is STATIC? What does this mean? So I can understand if it happens to me too!
Old Nov 14, 2006 | 08:17 PM
benzmodz's Avatar
W203 slightly modified
Static = noise
θόρυβος ραδιοσυχνότητας
