passenger outside mirror question
Old Nov 7, 2006 | 09:46 PM
terrence's Avatar
2011 Porsche Carrera GTS, 2009 BMW 750Li, 2011 Ferrari 458, 2011 SLS AMG, 2012 C63 AMG BS
Anybody have any luck making the passenger side exterior mirror dip down when engaging reverse? Tried everything and still no luck. Its a feature that is on all the other Mercedes that I know of, as well as almost all premium cars out there.
Please advise.
Thanks.
Old Nov 7, 2006 | 09:53 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Yep, mine works just fine. The right mirror switch needs to be engaged and while in reverse you must tilt it to where you want it the first time.
Old Nov 7, 2006 | 10:56 PM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Reverse mirror tilt
The procedure for setting it is in the manual. Note that the mirror switch has to be set to the passenger's side--this is opposite of my BMW.
Old Nov 7, 2006 | 11:56 PM
terrence's Avatar
I followed the advise and still it does not work. I also looked all over the manual and could not find the reference to it What page is it on? I have a 2007 model, in case the manuals are different.
Thanks.
Old Nov 8, 2006 | 12:33 AM
Mirror reversing position
Thanks.
In my 2006 manual, it's in "Controls in Detail/Activating exterior rear view mirror parking position" on page 196. Note: This is an optional feature and you may not have it. It's probably packaged with the power folding mirrors--not sure what package that's in now.
Old Nov 8, 2006 | 12:46 AM
terrence's Avatar
I have folding mirrors. My car has basically every option except distronic. However, someone is telling me that for 2007, they did away with that feature. Hope its not true.
Old Nov 8, 2006 | 01:35 AM
i7iceguy's Avatar
2010 E350, 2007 S550 - SOLD, 2007 ML350
I think they did get rid of this feature for 2007 models!! whats up with that??!
Old Nov 8, 2006 | 09:17 AM
sosh's Avatar
Originally Posted by GregW / Oregon
The procedure for setting it is in the manual. Note that the mirror switch has to be set to the driver's side--this is opposite of my BMW.
Greg, I do not recall what the manual says but on mine I set it with the mirror switch on the right (Pass side) mirror and it works normally.
Old Nov 8, 2006 | 11:08 AM
terrence's Avatar
Followed Sosh's advise and still can't do it. My manual does not refer to this feature when talking about the mirrors.
Old Nov 8, 2006 | 11:21 AM
i7iceguy's Avatar
I tried the same thing and it did not work for my 2007 model. Have you guys also notice there is no "Mono" button for the air condition? Meaning, its on dual climate all the time, although, the manual shows a mono button below the "auto" button. Looks like they messed up on the manual.
Old Nov 8, 2006 | 09:50 PM
Sosh, you're right--I got it mixed up with my BMW. I have altered my previous post so as not to confuse people. I can't believe they would delete this feature, as it is very useful for parallel parking. Terrence, check the Convenience submenu of the Control system for Mirror Adjustment Parking Assist. Email me and I will send you the page from the manual.
Old Mar 3, 2007 | 04:38 PM
Archaedus's Avatar
I'm sorry to bring this one back to life, but ever since I bought my 63 back in November, the non-tliting mirror thing has bugged me. I searched the entire boards, all models, and this thread seemed like my best bet. (Hopefully MB hasnt deleted the feature from 2007's as some have stated)
I tried all of the tips listed, but nothing has worked. If I leave the passenger mirror selector on all I get is a pretty little red light, still no tilt. I went through my settings menu and there is no "Convenience" option, only "Comfort" and under that menu there isnt anything about tilting mirrors, only the option to have the outboard mirrors auto-fold on parking. I've scoured my manual back to front twice and havent found any answers.
At this point I'm getting ready to take the suv in to the dealership to make them make it work. Unfortunately, where I park is a strangely shaped street and even with the back-up camera active its tough to get nice and close to the curb without risking hitting it.
Help me out!
Old Mar 3, 2007 | 05:34 PM
sosh's Avatar
Help me out!
Try this, put the mirror switch on the pass mirror, start the car, put it in reverse, tilt the pass mirror where you would want it when in reverse, then go to drive and see if it goes to the driving position. That should work if you have it.
Old Mar 3, 2007 | 07:59 PM
Vik888's Avatar
2008 E550, 2012 GL450, 2014 GLK350, 2015 S550, 2020 GLC350e
I believe the MONO button is only there if you buy the premium package which includes the 3-zone climate control, which is P3 I believe.
Old Mar 20, 2007 | 08:45 PM
organist88's Avatar
2004 ML350, 2006 E350 4Matic, 2007 ML350
Taking it to the dealer is exactly what you should do! My friend just received his ML500 2 weeks ago (my 350 is going to be picked up this saturday ... YAY! ) and had the passenger tilt-down feature activated through STAR Diagnostics. After it is activated, you program the setting like you normally would (right mirror activated, adjust mirrors to desired position, press memory, then press down, etc...)
*Note: you will not see this feature listed under the convenience settings after it is activated through STAR.
-Joe
Help me out!
Old Apr 7, 2007 | 08:44 AM
knepster's Avatar
gl450
Star Diagnosis
Hey Organist, I'm in LI and just got a 2007 GL, which dealership set the reverse tilt mirror program up for your friend?
Old May 20, 2024 | 02:51 PM
mrmatthewpaul's Avatar
W202 C43 Sadan, W203 C320 Estate,
Please advise.
Thanks.
I think you may have the wrong window switch.
Window switch that is from 2006 and older cars that share the same switch layout you have to go into the menu to activate this feature.
2007 and newer the programming is in the drivers windows. The caveat is LH or RH drive
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
