Brake warning light came on Help!!!!!
Old Nov 20, 2007 | 09:51 AM
hubert's Avatar
14'G63 AMG ,1994 Mercedes E500, 2020 Range Rover HST
In my ML350 with 14000 miles on it its time for new brakes(at least thats what the display says), my question is do i chang only the pads or pads and rotors its the first brake change???
Old Nov 20, 2007 | 10:02 AM
blazinginder's Avatar
AlabasterWhiteSL ObsidianBlackML
Only the pads...no way would the rotors have to be replaced already
Old Nov 20, 2007 | 10:06 AM
hubert's Avatar
Thank You... Do You thing if i change the pads my self the dealer will say anything when i bring the car back since its a lease?
Old Nov 20, 2007 | 11:26 AM
As long as you know what you're doing (which I assume you do) and the new pads etc don't do any damage to the car, I don't think it should be an issue...You could always call the service center and see what they say, not 100% sure on this
Old Nov 20, 2007 | 12:54 PM
lkchris's Avatar
'10 CL550, '12 GL550
Since you've a leased vehicle, best to use genuine Mercedes pads.
(It's best if you own the vehicle, too.)
Old Nov 20, 2007 | 01:05 PM
hubert's Avatar
I just bought the pads from NAPA front and rear with sensors for $105 bucks will change them friday and we see how they are....
Old Nov 20, 2007 | 02:27 PM
chilledbenz's Avatar
2008 R350 & 2008 C300
Could just be a faulty sensor. I had that problem on my 2000 ML, kept throwing up the brake light and when I took it in I had a faulty sensor. Have it checked out, to me 14,000 doesn't sound like a lot of miles on a set of brakes unless you been towing something.
Old Nov 20, 2007 | 03:06 PM
hubert's Avatar
Brake pads from NAPA no good they were the ones for W163 i guess its a dealed item only for now...
Old Nov 23, 2007 | 10:18 PM
btshep's Avatar
2020 GLE 580 | 2020 Ram 1500 Limited
if I am not mistaken doesnt Mercedes call for both the brake pads and rotors to be replaced everytime you do a brake job ? I thought this was the case since softer metals are used so the vehicle has superb braking ability. please correct me if i am wrong
Old Nov 24, 2007 | 11:05 AM
hubert's Avatar
Ok just came back from a dealer and let me tell all of you it was the most expensive brake job i ever have done.... Just to replace the brake pads it was $680 bucks which i think its redicilous but it was quick and fast so at leat im happy with that. To all of that think Mercedes changes rotors with every brake job its not true the first time its just brake pads...
