Successfully installed OEM LED Tail Lights
http://www.mercedesbenzgenuineparts....?siteid=214269
I was gonna go to benz and buy the OEM tail lights but i was afraid they werent plug and paly.
I have a 2009 ML63 fully loaded with Xenon headlights, but halogen tailights.
Will the LED OEM tailights be plug and play?
From what i know, the 2009 ML63 AMG come standard with the 'lighting package' wich include the OEM xenon headlights, but i think there was a small cutoff in 2009 where the LED taillight werent included on earlier models..
But would the same remain even with the light package, that i would need to reporgram the SAM even if i had the lighting package or OEM xenons?
would they put it in an LED capable SAM unit before the LED tails were even being installed into vehicles? i would guess probably not and the SAM needs to be upgraded too -- but again, just guessing
might as well check the part number before you do anything however. the unit is very easy to get to in the trunk panel on the right side. i don't think you even need a screw driver.
good luck..!
if you do have the right version, then you STILL need to get someone to switch the modes from conventional tail light to LED tail light. if you have a cool dealership they might do this for you, but i've seen others on this board not be so lucky. i have a good independent mechanic who did this for me for free (though he got a pretty nice tip for my appreciation).
"Right LED Tail light: A164 906 43 00 (replaced A164 820 28 64)"
Question:
is there any difference between both Parts (another colors etc.) or both Parts are fully exchangeable br & thanks for help
