AZN Optics 194 City lights for your W164
Old Apr 19, 2017 | 05:43 PM
  #126
AZN Optics's Avatar
SPONSOR/MBworld Guru
Yes, we have replacement HID bulbs. You actually use D1S.
Old Apr 19, 2017 | 08:44 PM
  #127
jimo's Avatar
GLE 350d Designo 2016, E350 2011 A207 Cabriolet
Great ! just send an order !
Thanks !
Jim
Old Jun 10, 2017 | 02:34 AM
  #128
AZN Optics's Avatar
Bump!
Old Aug 27, 2017 | 06:27 PM
  #129
AZN Optics's Avatar
Come join us at Mercedes Benz EXKLUSIV, an all Mercedes event - Sat. Sept. 9 2017. Long Beach, CA between 10am to 2pm. We will be having on site discounts throughout the event.
Old Dec 6, 2017 | 02:21 PM
  #130
AZN Optics's Avatar
bump. We now offer Hylux/Morimoto blended HID conversion kits to our lineup.
Old Apr 11, 2018 | 10:29 PM
  #131
AZN Optics's Avatar
bump
Old Apr 12, 2018 | 10:25 AM
  #132
jimo's Avatar
bump
Hi Guys did you found some License plate light who don't code ?
Old Apr 12, 2018 | 11:05 AM
  #133
AZN Optics's Avatar
Unfortunately no built in solution. We could slap a huge enough resistor on there that won't trigger code, but the heat it would give off would burn through the solder and leave you with a broken LED... obviously not something we'd offer. The only way around right now is to have an external load resistor so the heat isn't in contact with the delicate LED components.
Old Jun 25, 2018 | 01:36 PM
  #134
AZN Optics's Avatar
bump
Old Oct 12, 2018 | 06:26 PM
  #135
AZN Optics's Avatar
All orders shipped!
Old Jan 2, 2019 | 03:12 PM
  #136
AZN Optics's Avatar
Happy New Year Bump!
Old Jan 22, 2019 | 08:52 PM
  #137
streakpi's Avatar
MB GLE350
I have a 2011 ML350 - looking for low beam bulbs and fog lamps (at least) before I add high beams. My OEM lights are horrible...I can barely see the road. Any help!!!
Old Jan 22, 2019 | 10:58 PM
  #138
AZN Optics's Avatar
Yes, we can definitely help. For halogen low beams,we recommend our hybrid HID conversion kit: H7 Hybrid HID conversion kit. High beams also use the same H7 kit. For fogs, this will depend on package as it could be the same H7 kit or an H11 H11 Hybrid HID conversion kit. Check your owners manual which should specify which bulb type you have there.
Old Jan 24, 2019 | 11:08 PM
  #139
rx7turbo2's Avatar
2003 C 320 4 Matic, 2008 ML320CDI
Hey there. I run a set of your w5w bulbs in my parking lights (w164). Purchased April 2018. They’ve been great. Recently however they’ve started flickering or flashing when you first start the vehicle. With the key in the on position but vehicle not started (warming glow plugs) they both flash or flicker. Once the vehicle is started they go solid on. Also, maybe once every couple of weeks I get an error on the display regarding parking light malfunction, for both right and left, never one or the other. The lights are both on when I get this error and if the vehicle is turned off and restarted the error goes away.
Any idea what’s going on?
Old Jan 24, 2019 | 11:30 PM
  #140
AZN Optics's Avatar
How's the weather been? Electronics tend to act strange in colder weather when power lines aren't well insulated. We've had this occasionally happen with some customers in colder climates during cold start. After the car warms up a bit though, electronics go back to steady state and all good.
Old Jan 24, 2019 | 11:33 PM
  #141
rx7turbo2's Avatar
Yup, even though it’s been unseasonably warm up here it’s still winter, temp in the morning is likely -5 to -10 Celsius. Thanks for the quick response.
Old Apr 25, 2019 | 02:41 PM
  #142
AZN Optics's Avatar
bump
Old Jul 12, 2019 | 12:17 PM
  #143
AZN Optics's Avatar
By user request, we're working on a new product for those with painted sidemarkers and don't want any lights showing but also no error codes. This will be a circuit board design straight plug in replacement with no actual LED light source. We are in user testing right now, but hope to have it available sometime in Aug.
Old Mar 15, 2020 | 12:15 AM
  #144
AZN Optics's Avatar
Only 6 sets left of LED blanks for those with painted sidemarkers and want no lighting and no errors 194 Blanks. With supply chain issues due to Covid19 with our manufacturing in South Korea, not sure when we'll be able to get new units in.
Old Apr 16, 2020 | 10:15 PM
  #145
999turbo's Avatar
2005 e55 amg
I have a 2005 E55 and would like side marker and park light LED bulbs but don’t want to see DRL on,is this possible?
Old Apr 16, 2020 | 10:18 PM
  #146
AZN Optics's Avatar
You mean like the Blanks where you wouldn't see the light on?
Old Apr 16, 2020 | 11:03 PM
  #147
999turbo's Avatar
2005 e55 amg
I only want the side marker and park light only to work when I turn on the switch,right now it runs on DRL.
Old Apr 16, 2020 | 11:12 PM
  #148
AZN Optics's Avatar
Ok, so you're talking about a rewiring job. You'll probably need to splice in load resistors to close the circuit on the standard trigger wire to not throw errors and run a tap from switch line to the markers/parking..
Old Apr 16, 2020 | 11:24 PM
  #149
999turbo's Avatar
2005 e55 amg
Sounds like a bit of work,can you pm me prices for the LED bulbs in 8k?
Old Apr 16, 2020 | 11:29 PM
  #150
AZN Optics's Avatar
Unfortunately only 5000k pure white in stock 194 v5.2a canbus LEDs
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
