Anyone Running Winter Tires
08 ML350, 00 BMW 323i
If you are running winter tires what kind are you using?
I am thinking about the 235/60R18 Bridgestone Blizzak DM-V1.
Any experience with any other tires?
I have a 2006 ML350... I have been using Goodyear Ultragrip (235/65R17) for winter driving. We live on a rather steep winding incline in rural PA that is poorly maintained by the local township... at least at the times we have to use the road.
As discussed before in this forum, the M&S tires are generally plenty good for winter driving.
I have maintained that the extra piece of mind for the one or two times each season that the roads get really nasty the use of dedicated winter tires make all the difference for me.
2008 ML350 4matic
I keep the same wheels and switch out the rubber for winter....Conti Extreme Contact DWS. Love em, great wet/snow traction, yet whisper quiet on dry pavement. The tire meets "MO" standards and speed rating.
Don't buy a particular brand of winter tire just because somebody else loves it. The brand, model, and size you buy depend on the conditions in which you drive: deep snow vs packed snow vs ice vs wet roads, etc. What may work wonderfully for one person may be totally unsuitable for you, and vice versa. Also, remember that heavy SUVs can't always use the same tire as a lighter car -- many tire manufacturers make tires specifically for SUVs. (Same thing if you buy aftermarket wheels.) Tire Rack (with whom I have no connection) are exceptionally helpful when it comes to suggesting the best tire for you.
I run Pirelli Scorpions, which are a peformance winter tire made specifically for SUVs. They are not great in deep fresh snow, but I find them excellent for spirited driving in the cold on icy and snow-packed surfaces. They are a tad noisy in the dry. The only time I tried Blizzaks, they were fabulous for the first winter but rapidly lost their grip as they aged. But that was a few years ago, and Bridgestone doesn't stand still, so my experience may not apply today.
Is somebody there to give me a little bit light on this question ?
10x thanks ...
A.
2008 ML350 4matic
You can deactivate the TPMS for the winter wheels....I would skip the sensors.
I run the factory 19 inch wheels...255/50/19
So roadrutz rags on my post then turns his into a Pirelli commercial....nice. I used tire rack and the tires are also for SUVs.
1 Post
2011 GLK350, 2010 ML350, 2008 C63 AMG
I run the Pirelli Scorpions and they are great as the ML went through 2 feet of unplowed snowed last year in the Snowmaggedon that hit Washington DC. The tires are also very good in light snow and rain.
You are too sensitive. I was suggesting to the OP that he should consider a number of factors when thinking of winter tires, not just what other people's favorites are. I wasn't picking on you.
I've got Blizzak DM-V1 on my ML and I love them...I could climb a ski hill in them. My primary concern was grip in the snow and ice and not performance and I believe these to be the best for the severe winter conditions.
@ ZEMUN1234 TMPS aren't usually sold in Canada so you probably don't have it anyway. Check your valve stems and if they're rubber then you don't haveTPMS. TPMS doesn't work in the extreme cold and so they are rarely installed on Canadian spec vehicles.
1 Post
2014 ML350 BlueTec.
l have.............
Pirelli Ice and Snow's.....255/55/19's............Up here in southern Ontario, don't kid yourself..it is not southern, you need good winter tires....l have no complaints about this tire... l would recommend them to anyone...
'08 IS F; '09 ML 320 Bluetec; '10 X5 35d
First off, the Conti DWS are not winter tires. They are high performance all seasons that are designed to handle dry, wet and light snow. I run them as my summers on my X5.
We had a massive blizzard last Monday while I had the DWS's still on. They performed admirably for what they are, but are nowhere close to as capable as the Pirelli Scorpions that are back on the X5.
On our ML we run the Blizzak LM 25 4X4 and they are excellent.
10xthanks
1 Post
Suzuki Burgman Executive
I have checked and I have rubber valve stems. Once I have your attention, I am thinking go with smaller set tires for winters and some people go with 17" (my stock tires are 19", airmatic). My question is: can I put 17" tires or I can go only with 1 size smaller ?
10xthanks
10xthanks
2019 AMG GLE 63S
Michelin Alpin Going On This Week
After some thought, I went down to 18" OEM wheels and Michelin Latitude Alpin HP ZP for winter (255 55 18). I'll put them on this week and we'll see how they work over the Christmas holiday. We'll be going north along Lake Superior to try them out in some good snow. I'll let you know what I think.
By the way, it will be interesting to see if the ride quality is any better with the taller sidewall than the OEM 19" runflat Bridgestones.
ML550, F-350
First Class Wheel and Tire Package
Does anyone know if Snow Tires (or an extra set of Rims) are covered under the First Class protection plan....
I am thinking about getting a set of snow's but wondering if I get a blowout or something if they will be covered under the Mercedes First Class Wheel and Tire protection plan....
Does anyone have any first hand experience with this.
2019 AMG GLE 63S
Michelin Alpin Went On Last Week
I've always had good experience with Michelin tires, and never had any experience with the winter versions. I've had them on for a week plus now, and all I can say is WOW! Quieter than the all season Bridgestones on dry pavement, and the ride is much more compliant (but I'm sure this has to do partially with the sidewall being larger). But, for runflats, the ride improvement is noticeable.
One more week and we head for deep snow (they have had almost 2 feet so far) and the real test will begin. I'll let you know, but so far, better than expected. We should put about 1,500 miles on the tires on our trip over the holidays so it should be a good test with freeways, state highways, and city driving (ok small town driving) with steep hills.
I ended up going with the 235/60R18 Bridgestone Blizzak DM-V1. I also passed on the TPMS and I just ignore the tire light.
They have been great during the one snowfall we have had and I like them so far. More snow coming this weekend. Stopping and turning in slippery conditions is definitely much improved. They have a really deep tread 13/32 and are very soft. One person commented that they may wear quickly. I agree they may wear quickly and only last 2 winter seasons.
I have an old 323i and bought Dunlop winter sport 3Ds for it. They are not as good in the snow as the blizzaks but they are good in cold wet conditions but the performance/handling is not nearly as compromised as the Blizzaks on the ML. But we don't push the ML hard so that is not an issue.
08 ML350; 07' Acura RDX; 05'FX45; 03'Murano
10xthanks
10xthanks
The Canadian TPMS use the mechanical system, not electronic one.
