2009 ML550 HID
Does anyone know if all 2009 Ml550s came with HID headlights as standard equipment? or did it only come with the "lighting package" that includes adaptive lighting and LED tail lights?
Michael
Later I noticed that the "Active Curve Illumination" is in fact just turning on individual fog lights on the side where the steering wheel is turned to - left or right side. - Nothing else!
First time when I noticed that the Fog Lights are in fact the advertised “Adaptive Curve Illumination” system, I was a new MB driver. While parking inside a garage, I got off the car to check on how I parked/positioned the car. Imagine my surprise (and panic) when I noticed that one fog light was off while the other one was dimming, not fully turned on or off. From that moment I start ‘spying’ on my lights -headlights & fog lights.
Initially from the MB literature, I thought that the headlights are supposed to swivel. Later I noticed that the lights are fixed. And inside parking spaces I noticed that the fog lights are changing intensity, but thought that they do not move.
There is any way to see how the fog lights swivel? I would appreciate if you can please recommend any way I could check or see how the fog lights swivel. The ownership of this car is a continuous discovery process.
Thank you
The fog lights are also used as cornering lights and light the direction you are about to go under certain speeds. They will each light and dim to off depending on the direction you go. It is even smart enough to switch to the opposite cornering light when you select reverse. Fog lights don't swivel otherwise.
Actually, my brain is kind of our of gear as I have removed a fog light to replace the trim and I know perfectly well they don't swivel. Senility, here I come...
Later reconsidered the idea, and gave up the 'beauty' for the 'practical' use of fog lights in certain driving conditions.
Any considerations and/or advice on the subject, since it seems that you already did it?
Thank you.
These headlights are so dull i want to sell my ML550.
There are many dealers who sell these. Some are several hundred dollars, some are fifty dollars. I first started converting headlights because of a dealer who started advertizing here on mbworld. Look up HIDExtra.com, if you dont understand how to look up your car, call them and discuss it.
Basically, if you have a.. say a 9007 bulbs, you buy the kit to convert a 9007. You get 2 bulbs that fit into the 9007 hole, and you get 2 Ballast modules to hook to the bulbs and make the correct power for the HIDs.
Every car has a 12volt wire, positive and negative going to the headlight. The kit has wire connectors that plug to the factory wire, then to the ballast then to the bulb. And there you are, it works.
You have to choose the HID color 'temperature' , your choice is 3000k to 12000k and the colors go from dull white up to bright blue or purple. I find 5000k is light blue, 6000k is bluer, 8000k is noticably blue . after 8000k the brightness does not increase.I like the 8000k on my car. Some cars wiring is funky and you may have to do some modifying to get the wiring right, but supposiedly plug and play. You need fundamental mechanical and electrical skill to do it your self.
