Winter wiper blades 2010 ML
Old Feb 14, 2012 | 04:02 PM
mikapen's Avatar
My 2010 ML350 wiper blades collect ice in certain conditons. While this isn't new for my cars in general, I always equip my others with winter wiper blades, which fixes the problem.
Problem is, my ML has the proprietary wiper connectors that force me to use only M-B parts. As far as I know, there is not a M-B option for winter blades.
Are there any alternatives out there?
Old Feb 15, 2012 | 07:18 AM
zemun1234's Avatar
2005 E320 CDI (sold); 2007 R320 CDI (sold); 2008 ML320 CDI; 2014 ML350 Bluetec
I am looking for same answer ...I think it was one thread regarding BOSH wipers but I am not clear if they are making model which it should fit MB connector.
Old Feb 15, 2012 | 10:03 AM
roadrutz's Avatar
'09 ML550
"Proprietary wiper connectors"? I have had no problems fitting any blades I have bought. They always come with three or four different fittings, one of which always fits the ML.
Old Feb 15, 2012 | 04:23 PM
zemun1234's Avatar
Did you find correct model from Bosch ? I see you are in Canada and I am wondering if you can share some information ....
Old Feb 16, 2012 | 10:15 AM
roadrutz's Avatar
'09 ML550
No. I have never managed to connect with a Bosch dealer when I have needed wiper blades. The only place in town that I know sells them usually has to order them in and I tend not to have the patience to wait that long.
I did have a set of RainX blades that were fine for about three months then deteriorated rapidly, and I currently have silicon blades that carry a 2-year warranty (can't remember the make, but they were expensive -- maybe $25 each -- and I got them at Canadian Tire). They are excellent and almost teflon-like when it comes to ice and snow not sticking to them. Both sets came with multiple adapters and I had no trouble fitting them to the ML.
Old Feb 16, 2012 | 09:07 PM
mikapen's Avatar
I see you have an '09 ML. I believe the '10 is different and IS proprietary. None of the adaptors that I have collected in a coffee can are anywhere close to my '10.
I was disappointed with the RainX because snow and ice stuck even more than conventional blades when the temp got under 10 F. That was on my '03 C Class. And no, the RainX adaptors don't work on my ML.
Maybe I'm not trying hard enough?
Old Feb 23, 2012 | 08:24 PM
iankayem's Avatar
X350d GLE500e 2017, ML350 BlueTec 2012(sold), A200 2013, ML350CDI 2009(sold), Aston Martin DB7 2003
I have the 2010 model (actually built in 2009) which uses the aftermarket multifit wipers.
And Bosch do not actually make wipers, they only market Asian wipers under their own brand name.
Old Feb 24, 2012 | 01:02 PM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
If its that big of a problem did you ever consider putting 09' wiper arms on your vehicle?
Old Feb 27, 2012 | 10:25 AM
roadrutz's Avatar
'09 ML550
What are the 2010 fittings like? On my '09, there are two small v-shaped catches about 2" down the sides of the arm, and there is a slightly curved lip across the end of the arm. The wiper has to fit first into the two v notches and then it swivels up and snaps onto the end fitting. For my most recent set of blades I had to use pliers and bend the end fitting maybe 1/16" as the latch on the blades wouldn't quite snap into place over the end fitting as it was.
Old Feb 28, 2012 | 09:56 PM
gsrjc's Avatar
2011 GLK350, 2010 ML350, 2008 C63 AMG
You need to put in the wintertime windshield washing fluid
