DIY transmission fluid change
I would change it every 40k miles, I know most of the wear happens in the first interval, but they are expensive units and nothing is lifetime fluid.
Awesome! Thank you. That's a weird method they decided to go with but it's a good thing I know now!
Also, I believe there is an access port that will allow you to remove the plug in the torque converter to switch out even more fluid. Approximately 9 liters total.
just ordered this pump along with an adapter and a hose for about 180 after shipping & handling
Do you have access to a lift? This sounds like a pain to do without one.
My wife's ML is due. Trying to figure out if I want to do it myself or pay. Seems like after buying the pump, filler tool and tubing I could pay for it to be done.
Thanks, Greg
If you know your pump hose size before ordering (which I didn't), and order only one barb, the cost is about $ 17. Also, you can order 6AN fittings instead 8AN if you only need the 3/8" hose barb size.
I was coming up with around a $ 45 cost to order the Assenmacher ATF129 tool, and I didn't see any benefit to the higher cost tool.
