New tire options for ML350
I did have the Pirelli Scorpion Verde A/S 2 before on a Lexus RX and I was not impressed with them. New, they were awesome, but as they wore down (about 10k miles on them), they started to get quite loud. The first set got loud and out of round around 10k, so I got replacements for them (partially refunded from Discount Tire). After another 12k miles on the new tires, they started getting loud again. Snow traction was just average at best--Michelins Premier A/S were better. I don't understand how the Pirellis get such high ratings, maybe I had bad luck in my 2 batches of tires. In all, I would not recommend the Pirellis.
25,000 kms / 15,000 miles on a set of SUV tires is really disappointing.
I realize that OEM tires are purposely soft, because they typically handle and brake better, and aren't as noisy as replacement tires. So I try to replace tires with OEM choices to keep the performance that the manufacturer intended.
My question is, which Conti tires come as the alternative to the Pirelli's on the AMG rims? Anyone have this? What has been your experience?
Just got them replaced with another set of the Michelin premiers. Again; smooth sailing! Yes, they cost a little more. However, I had a F-150 with a set of Michelins that got 100k miles on them with regular rotation. That's what sold me on Michelin. They lasted forever, and were quiet and excellent handling in dry, wet, and snow. So in the end, do you really pay more for them? Just my personal experience.
Michelin doesn't make a tire that fits the ML350 AMG rims - checked their website and they say they don't make the size and specs I need....
265/45/R20 108H
https://pmctire.com/en/michelin-lati...5r20-104v.tire
Michelin's website knows the vehicle OEM size and rating, and shows no matches (I'm assuming that's because the load rating doesn't match)....
I'm not sure why they would require so much load, but maybe it's because they expect aggressive driving, etc.
I'll stick with the minimum OEM specs or higher.
Appreciate the ideas.
Technically the other tires are a higher spec for aggressive driving because they have a higher speed rating.
Just some food for thought. But by all means, go with whatever you're most comfortable with.
No issues with the tires. I don't drive real hard - all on blacktop and I have the car aligned about once per year.
The Continental CrossContact LX-20 has been a very good tire. Will probably also look at Michelin LTX tires.
Great ratings on tirerack.
Don't forget the PLUS. There is a tire with the same name, but without the plus, and it's not a good tire.
