Engine start-up noise 2010 ML350
If you are using a paper filter, it collapses and prevents oil flow to the upper valve train.
https://bevo.mercedes-benz.com/bevolisten/229.5_en.html
Meanwhile, wanted to pick your brains to see if someone has a similar experience. I wanted to start a new thread, but this thread came up in my search.
Thanks,
I replaced the fully charged battery and started the car again. This time, it started with no symptoms at all. I cleared all the thousands of error codes and re-scanned, no error whatsoever. Once again, it's amazing that how these cars are so sensitive to low battery charges. I have a BMW X5 and has no such sensitivity. Lesson relearned!
Hopefully with the warm weather around the corner, this will not happened. It was truly a scary experience.
Thanks Major for pointing me to the right direction and result.
