2010 ML350 Side Mirror Blinker error
Explain why you had to replace both tail lights.
I suppose aftermarket tail lights were installed and blinker circuit resistance change may be the result of side mirror blinker error as wrong tail lights may be purchased.
Aftermarket LED tail lights may exist for both ML versions:
- "Bulb to LED" as upgrade to LED tail lights
- "LED to LED" as replacement of broken LED light.
Retrofitting genuine LED tail lights for W164 requires rear facelift version SAM purchase and programming.
So please explain more about tail lights replacement, it may be a root cause for blinker error.
Since you have folding mirrors, those very thin wires to the signal indicator are subject to breakage. You have no alternative but to remove the blinker.
The wiring diag. for the blinker is only available through the right Door Cont. Module (N69/2). M21/2 is the rt. mirror and E6/6 is the blinker, all at the end of the diag.
Remove the mirror glass and then remove the two small screws holding the blinker.
I ended up soldering these amazon ones in as the plug is wrong... As you can see in the pic above in this thread red wire is positive black is negative. These things came to me with black wiring and no marking on the housing unlike the factory housing which do have positive and negative marked on the housing.
The drivers side one I wired up the same as the factory drivers one and same with the passenger copying the polarity markings of the OEM housings not these knockoffs. They are different polarity on the oem housing side to side but the wires do signify "+ and - red and black.
Anyway both indicators work. Problem is I get warning lights on the dash and it clicks faster on the dash only (the indicators themselves dont speed up) after about 8 to 9 flashes on each side.
I just measured the factory units resistance and both came out to 340ohms.
Im thinking I should maybe go back in there and check the resistance of these aftermarket ones and see if its the same if not add resistors until it is?
Has anyone figured this out? The mirror indicators are controlled by each respective door sam module and I had a quick look through both of them for any coding options that might let it work properly but cant see anything. Do you guys think if I update both door modules I might get an extra option that might work for me??
I also have led fog lights which I may try updating the software in the front sam to see if that gives me any options for led fogs?? as currently when looking through the front sam I dont see the option for leds in the front of the car.
Or can I just delete the codes in vediamo somehow and begone with the error warnings altogether somehow?
