WHAT'S THE RIGHT TRANSMISSION OIL? URGENT PLS!!
Old Jul 12, 2018 | 04:30 AM
Burac's Avatar
2009 ml350 4matic
Lost some fluids changing my rear crankshaft seal. Needs 2 litres. Please is this the right transmission oil for my w164. My part supplier sent me this pic
Old Jul 12, 2018 | 05:26 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Look at the label on the front of the bottle and compare it to the M/B numbers on sheet 236.14.
https://bevo.mercedes-benz.com/bevol...4&suchbegriff=
Old Jul 12, 2018 | 01:37 PM
Burac's Avatar
2009 ml350 4matic
thanks a lot. Think I'll be picking up the Liqui Moly atf 1600 tomorrow then. Car still packed there
Old Jul 12, 2018 | 01:56 PM
Burac's Avatar
2009 ml350 4matic
I already have some litres of the above ATF in the above picture in the car. My mechanic says i require 2 more litres for top up. Hope it's ok topping up with Liqui Moly Toptec 1600 recommended from the link you sent @ Maj. Dundee. Been using it close to a year now, with no issues.
Old Jul 12, 2018 | 07:27 PM
lkchris's Avatar
'10 CL550, '12 GL550
It depends on the year of production of your transmission as to the correct fluid ...
File Type: pdf
Old Jul 13, 2018 | 04:17 AM
But is that fluid on the list? What is the part number on the front label?
Old Jul 13, 2018 | 04:44 AM
Burac's Avatar
2009 ml350 4matic
A001989240310
Old Jul 13, 2018 | 04:57 AM
Burac's Avatar
2009 ml350 4matic
February 2009. Also from the original list I saw the Liqui Moly atf top tec 1600 is approved. My question is mixing with the original fluid. Think the colour was blue/green. I haven't used the Liqui Moly atf and I don't know the colour
Old Jul 13, 2018 | 05:58 AM
Burac's Avatar
2009 ml350 4matic
have another with A001989680313
Old Jul 13, 2018 | 08:13 AM
mRaposo's Avatar
ML350 2009 CDI
7-speed automatic transmission 722.9 up to transmission sequence number 2834526 uses specification 236.14.
7-speed automatic transmission 722.9 as of transmission sequence number 2834527 uses specification 236.15.
There is no prohibition on mixing old transmission oils with new ones at BEVO, but I believe it would be best to add oil of the same make and model.
