Anyone know the torque for the pulley that you take off for thermostat replacement?
Old Jan 20, 2019 | 05:56 PM
kino1161's Avatar
2008 ML350 4Matic
I’m about to replace the thermostat in my 08 ML350 and wanted to know if anyone knows the torque specs of the pulley that you take off in fron of the thermostat?
Old Jan 20, 2019 | 10:33 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Here it is.
Old Jan 21, 2019 | 01:50 PM
kino1161's Avatar
2008 ML350 4Matic
What is Nm 35 and 25?
Old Jan 22, 2019 | 02:51 AM
Nm stands for Neuton meters, named after Sir Isaac Neuton.
Look at the PDF I previously posted and I converted Nm to foot pounds.
Old Jan 22, 2019 | 08:13 AM
kino1161's Avatar
2008 ML350 4Matic
thank you
Old Oct 26, 2019 | 05:53 PM
anavabi's Avatar
2006 ML500, 2008 ML350
Originally Posted by Maj. Dundee
Here it is.
Major,
What would you consider as initial installation and follow up operations for the guide pulley as stated on the R&I. I just loosened and retightened the bolt on the guide pulley would it be initial or follow up?
Old Oct 26, 2019 | 06:57 PM
Are you replacing the thermostat too?
Old Oct 26, 2019 | 07:39 PM
anavabi's Avatar
No. On my ML350 there is a squeaking noise that I'm working to figure out. I changed the v belt a few weeks ago because it was worn out. It got rid of the noise until a few days ago. The noise is back. I tested all the pulleys they're all nice and sound, no wobbling and run quite freely. But I noticed a very tiny wobble on the idler pulley, I loosened the center bolt and retightened it. That's why I thought I torque it the right amount to see what happens.
Here's the squeak in action
https://www.youtube.com/watch?v=Zi9c...ature=youtu.be
Old Oct 27, 2019 | 11:53 AM
Read the PDF again and scroll to the bottom.
File Type: pdf
Old Oct 27, 2019 | 12:43 PM
anavabi's Avatar
Thanks for clarification
