Front right inner turn signal stay on always
Old Apr 25, 2019 | 08:25 PM
Talal Al Hadidi's Avatar
ML350 bluetec 2010. W164
Hi every one
I have problem with my ML350 bluetec 2010 which is front right inner turn signal stay on since 6 months
I checked the following items ;
1. The right harness E2e5 stay +ve always so I loose the sleeve and check it toward the cockpit nothing wrong or contact
2. Open the right head light connect it to the left harness the signal off and normal working , I disassybled the head light every thing ok
3. Disconnect the hazard botton , it still the same
4. Checked front ,under seat and rear SAM all fuses and relays ok
5. Disassybled the steering combination control nothing wrong with it
6. I live in Iraq - Mosul there is no technicians have experience with new mercedes cars so I check it by my self
please help my to solve this problem
waiting your kind urge
please accept my greetings
THANKS 😁
Front right inner turn signal stay on always even when car off
E2e5 +ve always even when car off
Old Apr 25, 2019 | 11:53 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
The front turn signals are controlled by the front SAM, connector "C" wire #31 Pink/White.
With the key out of the ignition, test wire for 12v, making sure that it is a Pink/White wire or Pink.
If there is 12v, remove conn. C and check for corrosion.
Post back with results.
Old Apr 27, 2019 | 02:01 AM
Maj. Dundee
THANKS for you kind reply
the front SAM in my W164 look like BUS as in the attached photo and not like the photo you attached 🤔
if there is any suggestions I'll be greatfull to you sir
thanks
Old Apr 27, 2019 | 04:45 AM
Where are the main battery, the Auxiliary Battery and the front SAM?
Old Apr 27, 2019 | 05:03 AM
Maj. Dundee
Under the passenger seat
Old Apr 27, 2019 | 05:56 AM
But your photo shows that nothing is there.
Old Apr 27, 2019 | 06:31 AM
Maj. Dundee
Yes Sir
That what I found 😁
Old Apr 27, 2019 | 07:04 AM
Well then where is everything?
Is your truck right or left hand drive?
Old Apr 27, 2019 | 07:14 AM
Look under the right rear seat.
Old Apr 27, 2019 | 07:23 AM
Dundee
It's left hand
I just open the passenger floor Nothing under it as in attachment
And I found rear SAM under rear right seat
Old Apr 27, 2019 | 07:28 AM
Maj. Dundee
It was the right passenger seat where the battery were I looked
You mean the left seat ( driver seat ) ?
Knowing that the vin no. Is
4JGBB2FB6AA593877
Thank you Sir for help me
Old Apr 27, 2019 | 07:46 AM
Maj. Dundee
I think that I have to remove the passenger seat to reach the SAM
Because there is a black plastic cover to the right of the battery May be the SAM under it
4JGBB2FB6AA593877
Old Apr 27, 2019 | 07:57 AM
First move the right front passenger seat all the way forward. Then flip down the right rear passenger seat.
Look in your owner's manual for instructions.
Old Apr 27, 2019 | 08:09 AM
Old Apr 27, 2019 | 11:08 AM
Maj. Dundee
Thank you Sir
Am grateful to you 😁
Old Apr 29, 2019 | 05:41 AM
Mission completed 😊
Today I reached front SAM after removed passenger seat , as you instruct me removed connect C wire 31 was clean , so I disassybled the SAM I found some salted areas as in attached photo , I clean it with white spirit , dry it and reconnect it
It work 😂
But right SRS warning light on !
Old Nov 30, 2025 | 11:35 AM
whippersnapper's Avatar
Unhappy Front sam removal
W164 2010 ml63-I am having very similar issues and have the same warning lights as well as the indicator light staying on for the passenger side. I didnt think it was the rear sam but cleaned that one first bc it was so easy to access, changed nothing. I am trying to reach the front sam and have removed the front passenger seat and I can see that it is under some sort of plastic cover above the sam but I cannot possibly get the thing out and have removed any bolts that I can see, I saw in another thread someone had to remove part of the pillar???? the heck but I cannot figure this out or find anything showing how its done and I have checked alldata as well. Thank you for any advice.
Old Dec 1, 2025 | 10:45 AM
the front sam not there, it near to the small battery
Old Mar 14, 2026 | 01:51 PM
Despite every bit of research I did, I had to figure it out myself. Yes that is the front sam and in order to remove it-first I took the passenger seat out and the weather strip in the front and rear door. I also took the main battery and aux battery out. I was then able to remove various trim pieces along the floor so I could lift up the carpet. There is a black plastic tray above the sam preventing you from removing it. After you get all of that out and the wires in the way you can remove this cover in my picture above. The front sam was very corroded and it may need reprogramed but I cleaned it as best as I could and put it back in. It did not solve any problems so I figured I would check every single fuse again. There was a bad fuse for the obd port so I replaced it and then I was able to check the codes-there was a ridiculous amount so I cleared them all out and all my problems went away for the most part.
