DSR Inoperative, Battery Warning, COMAND cycling ON/OFF, No turn Signals etc
Old Sep 6, 2019 | 05:18 PM
bendog's Avatar
2007 C200 W204 Petrol, 2013 ML350 BlueTEC
Hi..I'm logging this problem so others can learn. It's from a mates 2007, ML350 4Matic, Petrol. Initially the following occurred whilst driving: DSR Inoperative, Battery Warning, COMAND on-off-on-off-on, no turn signals, A/C won't turn ON, wipers do one(1) sweep, no horn.Also when parked with door open, interior lights cycling OFF/ON). My code reader (iCarsoft MB) is unable to talk to either SAM's. Power is confirmed to both SAM's. I've opened up the front SAM and has no visable prblem- clean as. Mobile MB Mechanic will be attending within next 5 days- I'll update then.
Old Apr 28, 2020 | 08:54 PM
lordofthering's Avatar
2008 ML320 (W164) - 201K Miles
I am having exact same issue in my 2008 ML350. Anyone can tell me what could be the issue ?
Old Oct 13, 2021 | 02:49 PM
MarleyB's Avatar
ML350
Any updates on your issue? My ML350 is now having the same issues. I just replaced my engine 3 months ago and just last week put in a new battery. My vehicle started and I drove for maybe 20 seconds before receiving all the alarming messages/issues (DSR inoperative, battery warning, SOS messages, audio not working, no turn signals...). Any help is much appreciated.
Old Oct 13, 2021 | 03:13 PM
I wish I remember how I resolved issue but it must be something simple. Did you try to reset your vehicle by turning steering vehicle fully Left hold and turn right and Hold ? I will post back if I remember anything.
Old Oct 13, 2021 | 03:20 PM
When did you last drive your car ? Are you driving your car right after battery change and you are having this issue ?
Can you try to check your battery voltage ? and possibly charge your battery ?.
Old Oct 13, 2021 | 03:28 PM
MarleyB's Avatar
ML350
Thank you! I will try both suggestions and let you know. I did drive right after battery change and then those messages appeared so immediately turned back and parked. Then received another message that said "drive to workshop without shifting/changing gears." Have not driven it since in fear of the worst.
Old Oct 13, 2021 | 03:31 PM
Thank you! I will try both suggestions and let you know. I did drive right after battery change and then those messages appeared.
Below is reset procedure:
You have to start the engine, and turn the steering wheel twice fully lock to lock.
If that does not work:
Please recharge your battery fully and try it. I looked at date when I posted my problem and it was last year and I do not recall me doing anything major. Must be battery was drained in winter and I would have charged it or something simple so do not worry to much. Dig deeper on internet and you will find something.
My guess is your battery is not fully charged. Please charge directly from under the passenger seat.
Also read below thread:
https://www.benzworld.org/threads/ma...ement.1699583/
Old Oct 13, 2021 | 05:12 PM
bendog's Avatar
Hi...yes this problem was solved. The Central Gateway had water ingress and had failed (parked on a slope and it bucketed down rain- 70mm in one day). The unit lives under the left hand front seat on an ML here in Oz.
Old Jan 12, 2023 | 08:42 PM
TahoeML's Avatar
Mercedes ML500 2006
What did the fix entail?
Did you have to fully replace a component? Or did it just dry out and fix itself?
Old Jan 30, 2023 | 01:07 AM
bendog's Avatar
Had to replace unit... A place in North Sydney was able to supply one and a seperate guy came to workshop to re-code it.
