Coolant Temperature Sensor location
Old Sep 11, 2019 | 11:30 AM
Trerivers's Avatar
2009 ML350
Engine Compartment
Where is the Coolant Temperature Sensor on my 2009 ML 350? Please attach any link(video or otherwise) that may help in its replacement. I am a DIYer.
Old Sep 11, 2019 | 02:07 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W164 forum...
Old Sep 11, 2019 | 04:16 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
At the rear of the engine.
Old Sep 11, 2019 | 04:55 PM
Trerivers's Avatar
2009 ML350
Talking
Found it, removed it, and replaced it. However, after install with new o-ring, part does not seem to fit as snug as the part I removed. Part numbers match(though it is aftermarket), and it also passed the eye test. Kind of afraid to top of fluid and start up. Don't want to cause another issue. Any insights?
Old Sep 11, 2019 | 05:09 PM
Aftermarket is the key word. Buy one from a dealer.
Old Nov 3, 2019 | 12:53 PM
tmryan's Avatar
Did you have any issues removing the sensor. any tips appreciated
Old Nov 3, 2019 | 01:19 PM
It's one screw, what could be the problem.
Old Nov 3, 2019 | 03:52 PM
tmryan's Avatar
Sound like it's no big deal. Always appreciate input from those who have done the task. Don't know--if you don't ask.
Thanks for the input.
Old Nov 3, 2019 | 05:34 PM
What year and model, gas or diesel is your veh., Ill give you the instructions?
Old Nov 15, 2019 | 06:46 PM
tmryan's Avatar
2010 E350 4matic
Old Nov 16, 2019 | 06:39 AM
2010 E350 4matic
You are on the wrong forum but here is the location.
Old Jun 14, 2020 | 12:02 PM
Harinderassie's Avatar
2012 GL350 Bluetec
Hey Maj. Dundee can you help me i am looking for a coolant temperature sensor for a 2012 Mercedes Benz GL350 Bluetec. Also the circuit diagram for the radiator fan module to the ECM. As my car is overheating and the cooling fan doe snot move.
Old Jun 14, 2020 | 01:14 PM
The following diagram is for W164 CDI as I cannot gain access to X166 diagram, but it should be the same. Do not apply voltage to any line as you may toast the ECM.
Check fuse #7 100 amp at the Front Pre-Fuse Box for the fan M4/7, to see if it is blown.
Here is the diagram and legend.
File Type: pdf
File Type: pdf
File Type: pdf
Old Jun 14, 2020 | 01:18 PM
2012 GL350 Bluetec
Thank You Maj. Dundee just wondering do you have a more clear WHIP (R) printout. IT is hard to make out the writing on the blackground paper.
Old Jun 14, 2020 | 01:23 PM
When it opens up it will be black, just scroll down.
Old Jun 14, 2020 | 02:21 PM
2012 GL350 Bluetec
Sorry to bother you, but can you show me in a picture where this fuse is located that is outlined below sir
Old Jun 14, 2020 | 02:26 PM
There are probably two fuse boxes under the hood, one large and one small (Pre-Fuse Box).
Old Jun 14, 2020 | 02:41 PM
Do you have this under your hood?
Old Jun 14, 2020 | 03:44 PM
2012 GL350 Bluetec
Ok after a lot of reading and testing we found out it is the fan module that is shot. ECM has good power going intot he unit. I guess i will be looking for a complete fan.
Old Jun 14, 2020 | 03:47 PM
Very expensive new.
Old Jun 14, 2020 | 03:49 PM
2012 GL350 Bluetec
Thanks i have full power there.
Old Jun 14, 2020 | 04:40 PM
2012 GL350 Bluetec
We took the radiator fan out and noticed that the outer bearing is broken and it would not move, we have removed the bearing and it moves freely. Now i just have to figure out what type of bearing this is an di might be good a few hundred dollars if i do not have to get the whole fan unit.
Old Jun 15, 2020 | 05:41 AM
A new fan from M/B is approx. $600.
If you get a used one or buy an aftermarket one, you might have the same prob. in 6 months. Choose wisely.
Old Oct 26, 2021 | 10:17 PM
Liro's Avatar
ML350 2010 bluetec
Hi Maj,
I have a ML 350 Bluetec of 2010, and on idle very ofter the RPM's stays at 800, but usually it should be at 700 RPM. I dont get any code at all and very difficult to know whats going on. Have you seen something similar from your experience? Could the coolant temp sensor intermittent signal cause that?
Old Oct 27, 2021 | 09:26 AM
Originally Posted by Liro
Hi Maj,
Yes it could, BUT you should have a code # to back it up. Do you have a scanner type reader to scan all modules?.
Look at the PDF and see all the possibilities that could be the cause
