Rear right body acceleration sensor
Old Apr 23, 2020 | 10:27 PM
Marko Savic's Avatar
ml350 w146
I’ve got some trouble to located rear body acceleration sensor on my 2010 ml350
does anyone has any experience with this sensor
That’s what comes up on my MB C6 SCANNER but I can’t find it
I’ve got this but not much help as behind panels is lots of things n can’t find it
THANK YOU
Old Apr 24, 2020 | 08:02 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Here is the location.
Old Apr 24, 2020 | 08:19 PM
ml350 w146
Can
can’t believe I don’t have that
do you know maybe does connection can be pull out or is always mounted to the car?
THANKS HEAPS 👍🏻
Old Apr 25, 2020 | 02:17 AM
Here is another PDF that confirms the location. Maybe the previous owner removed it and didn't want to spend the money to replace it.
Old Apr 25, 2020 | 05:05 AM
ml350 w146
yeah that’s what I’m thinking as well previous owner removed it but I can’t find sensor connector where is plugged to and where it goes.
i’m not sure if they can remove the cable or not?
thanks heaps I appreciate your help
Old Apr 28, 2020 | 11:48 AM
lkchris's Avatar
'10 CL550, '12 GL550
Interesting to read that these sensors enable Airmatic to counteract brake dive. Yet another feature the fools that replace Airmatic with steel springs lose.
Old Apr 28, 2020 | 06:55 PM
ml350 w146
I’ve got a sense but seems like holes doesn’t fit or wrong sensor
anyone has any idea of this?
Old Apr 29, 2020 | 02:47 AM
Please UPDATE YOUR PROFILE in USER CP to include the year, model 350 CDI and where you live.
Old Apr 29, 2020 | 03:02 AM
ml350 w146
ML 350 2010 Australia-Melbourne
Rear body acceleration sensor for airmatic
Old Apr 29, 2020 | 03:09 AM
You didn't follow the instructions.
Old Apr 29, 2020 | 03:50 AM
You bought the front sensor. The highlighted sensor is the one you must order.
File Type: pdf
Old Jun 5, 2023 | 01:07 AM
alive19's Avatar
GL320 2007
I'm just going to throw it out there, your car doesn't have a rear sensor from factory.
No idea what happens if you try to install one.
The thing that confuses me, you have access to xentry/das, so why don't you use the the EPC with your VIN? It will tell you the part number (in your case it'll be greyed out because you don't have one).
