Chasing down water leaks from headliner
I've been trying to do alot of research on this but has anyone else ran into this issue? Previously I had a sunroof seal on my BMW which resulted in my backseat getting flooded! I'm trying to figure out exactly whats the deal with the sunroof drains, theres so little space in the back of the sunroof, I can't even see where they are or how to even service them. Even with a slight hole in the seal they should be draining with the drains right? Perhaps one of the drains is disconnected? I may try to see if I can remove the door hanels on the right side and see if I can shine some light to access any of the drains. Its been a nightmare so far. If anyone has any insights or tips it would be appreciated.
Please post a photo of the 2mm gap.
Great work hunting down this leak (kudos to you to taking half of your headliner off...no small task)! I too have been plagued by water damage to the rear SAM unit and figured I'd share my experience here to try to consolidate the solutions surrounding this water ingress issue. During significant rain events I would always get water in and around the SAM unit with significant pooling of water directly on the top of the SAM connectors as well as on the metal mounting bracket:
(picture of water ingress with SAM unit removed)
After browsing this forum for many months I have tried all of the suggested solutions that are out there. I have gone through properly replaced the seals around the tail light housings with the updated thicker seals and water was still getting in. I have checked all of the sunroof drains and none leaked water into the vehicle. I sprayed all rear window seals with a high pressure hose, no leaking from there. I sprayed the perimeter seal of tailgate with a fine water stream and still no leaking there. I tried as best I could to spray up from the underside of the vehicle into the rear quarter panel area and could not get any water into the rear SAM area.
Today I finally took the time to systematically go through every single seal in the rear half of the vehicle (starting from bottom of the tail gate gasket and working my way up to the seals around the sunroof) to see if I could isolate the leaking seal. After about an hour I found that the accordion style rubber boot on the lift gate hinge was leaking on the bottom side of the boot where it mates up with the plastic body shroud!
The rubber itself was completely in tact and visually looked OK, but when I pulled back the rubber boot I saw that the hard plastic snap feature that it was installed onto was totally destroyed! This broken piece was allowing water to pool up on the bottom side of the boot, weep through this cracked mounting connector, and subsequently run down the wire loom located inside of the D pillar and drip directly onto the rear SAM.
When I poured water directly into this hole, the resulting water that pooled inside of the rear quarter panel was an exact match (in both pooling location as well as splash pattern) to the water ingress that I would experience during rain events. I have since sealed up the perimeter of the seal with weather stripping adhesive, and so far I have not been able to get water past it! I will continue to keep my SAM out of the quarter panel for the next few weeks just to be on the safe side and monitor for any signs of water ingress, but fingers crossed this is the solution to my problem! I just wanted to share this information here so it can be a "one stop shop" for locating leaks that can (and do) damage the rear SAM units.
Best,
Joe
