Replaced the radio head unit that was bad, now theft activated
Then, I got the anti theft activated - turn ignition on and restart message. I did it several times and also exited the vehicle, locked and waited, but message is still there. Currently no sound, nav, or back up camera.
I have the donor vehicle VIN but there is no prompt to enter a radio code so I haven't tried to get the code. I have no star-xentry access.
Any suggestions?
What is the part # of your old radio and what is the part # of the donor one?
I thought perhaps the problem is with the misalignment of radio codes between the former unit and the donor unit in the COMAND system. I haven't seen anything on the COMAND interface on the instrument cluster about entering a code as I would have expected.
Thanks Bro,
Greg
Even though the W164 radio system does not require the security code entry like the W163, it recognizes that it does not belong to you vin#.
http://mercedes-benz.custhelp.com/ap...-comand-screen
The old radio had the blank, but slightly glowing white screen disorder. Otherwise the music played but I could not use back up camera or navigate the screens properly due to the blindness.
The other plan I thought of was to put the screen from the donor unit into the old unit and see if that works. I can buy an aftermarket high tech head unit with vastly expanded capabilities for less than I paid for the used donor head unit, but I didn't want to lose fidelity with the optical audio to the amplifier with the Harmon Kardin audio package.
Lacking a high end star system that could be my only option.
Might I suggest you check your connections? Sounds like something might have come loose since it worked for a little bit. Maybe spray the electrical connectors with contact cleaner. Make sure the fiber connection is clean. Just a thought before you head to the dealer.
I put the old unit back together and saw that is was quite simple to remove and install the whole front with keypads, screen and all. Figuring the PIN was probably stored in the front somewhere, I doubted it would work, but it was so much easier than removing just the screen, so I tried it. I swapped the entire front from the new unit and old unit. I put the old unit back in the vehicle with the new front on it and it worked like a dream. It has been weeks now and still working so I think it is good.
Thank you.
Thank you.
Pictures...seems like a good idea.
Trey
