Water in my ML320
At the bottom of the floor you will see 3 or 4 flat rubber seals. Remove them and the water will drain out, then reinstall them.
To insure that this will not happen again, replacement of the tail lamp is required.
As for water in the battery storage area, you should remove the 4 bolts at the R/F seat and tilt it toward the front & then disconnect the NEGATIVE battery cable first & then the POSITIVE cable last. Then remove the small battery and then the SAM and anything else until you reach the bare floor.
Then see if there are drain holes. If not, then you have manually dry it out. If the SAM is wet, then you will have to remove the plastic covers and see if there is corrosion.
When reinstalling the main battery, POSITIVE cable first & NEGATIVE cable last.
Where do you live?
If there is water where the battery is then you just have to remove the seat and take out both batteries and dry it out.
