2009 ML 320 OM 642 W164 persistent fault code 14A600, lack of power
You must check all wiring harnesses connected to the EGR. Other than that, I have no other suggestions.
{QUOTE=rrvtechcon] Checked wires going to Exhaust Back Pressure sensor and I got good signal ground, I also got the 5 volts ref voltage confirmed OK but the signal line from EBP sensor to ECM is only .70 volts at idle and only 1. 6 volts @ 4000 rpm. This is too low, I should be getting at least 3-4 Volts same as of the MAP & MAF sensors signal voltages. I am ordering new EBP sensor. By the way, when I cleaned the EBP sensor with brake cleaner and blow compressed air and put it back, I was able to rev over 3500 rpm but after 30 sec. check engine light came back again. Will see after I replaced the sensor.
Unfortunately, I was too fed up, so I surrendered and sold it without resolving the problem. The buyer told me he will just delete the EGR and have his friend do the ECU tune up to remove the EGR from the system. But before I sold it I was able to ask a good Mercedes Benz indy shop and gave me a quotation for checking all the sensors & wiring associated with the EGR like the speed control sensors from the 4 wheels, back pressure, inlet air temp sensors, MAF & MAP sensors too but the labor hour cost is high to proceed that I just decided to sell it and ordered a 2021 Tesla model 3. This Mercedes Bluetec SUV is very problematic and also a money pit when it reaches over 100K km mileage they have a poorly designed emission system component compared to other vehicles. I hate this car brand and will never buy a Mercedes car again. I hope this information helps you.
