2007 ML320CDI 4Matic - Correct Engine Oil
Old Jul 14, 2021 | 02:44 PM
mercml320's Avatar
2007 ML320 CDI 4Matic
Hello all,
currently I just purchased 07 ml320 cdi with 210k miles and my Dalmia is finding the correct oil weight and brand.
I have checked https://bevo.mercedes-benz.com/bevol...229.51_en.html and I found out that I can use Mobile 1 ESP 5w-40, but this one has disappeared.
I found other brands like Valvoline SynPower MST C3 5W-40, Castrol Edge Turbo Diesel 5W-40 or LIQUI MOLY Top Tec 4110 5w-40 or 5w-30 will these be okay choices.
Also will 5w-40 be okay to use as well as the car has high miles and in Florida or I should use the Mobile ESP 5w-30 mobile.
Thnx.
Old Jul 29, 2021 | 10:18 AM
dgiturbo's Avatar
His 2019 RAM Cummins Turbo Diesel Laramie; Her's 2007 ML320 CDI P3; Mine BMW R1200R
I have switched to Penzoil Platinum Euro 5W30
It meets Mercedes 229.51 specs, and made from natural gas so really pure. Pay attention to the labels cause there are several 5W30 oils in similar packages that do not meet 229.51 specs. I buy form Amazon. The others you mentioned should work IF they have the Mercedes 229.51 specs on the bottle.
Old Aug 2, 2021 | 03:47 PM
mercml320's Avatar
Yeah that sounds like better choice, thank you for reply.
Old Aug 12, 2021 | 05:11 PM
lkchris's Avatar
'10 CL550, '12 GL550
Must use oil with either of the following printed on the bottle
Mercedes approval 229.51
mercedes approval 229.52
since 52 has superseded 51, that’s probably what you will find
just 229.5 is not acceptable
Old Sep 22, 2021 | 02:23 PM
mercml320's Avatar
When I checked under the hood there's two stickers showing up 229.31 and 228.51. Will rotella 5w-40 be okay or just stay with the pennzoil 5w-30. Is the pennzoil 5w-30 be okay in florida or is it light oil. It been really hard to find the 5w-40 that are 229.51 in stores or 229.31. Thank you in advance.
Old Sep 22, 2021 | 03:15 PM
CLK Group's Avatar
2008 ML320CDI 4Matic, 2006 C350
Current diesel spec: https://bevo.mercedes-benz.com/bevol...229.52_en.html
I currently run: https://www.motul.com/ca/en-US/produ...clean-efe-5w30
Old Oct 20, 2021 | 11:45 PM
Dinismb's Avatar
2005 Mercedes C230 Kompressor, 2008 GL 320 CDI, 2008 ML320 CDI, 2016 GLE 300d AMG Night Package
I stick with the oem mobil 1 5w30 ESP formula. Ive opened the EGR on the ml and gl and no carbon build up whatsoever. 193k miles on the ml and 214k miles on the gl.
Old Oct 20, 2021 | 11:51 PM
mercml320's Avatar
5w-30 esp is hard to find at my local shops.
I'm currently in Florida.
I just used the pennzoil since it's meets the bevo.
I have 216k on my car 🙌
Old Oct 21, 2021 | 07:01 AM
Dinismb's Avatar
I cant find it either. You can only buy it at advance auto parts if you order it.
Ecstuning.com sells the whole kit.
Old Oct 21, 2021 | 04:10 PM
mercml320's Avatar
I know this is a sensitive subject when it comes to motor oils, but since my car shows bellow in engine compartment cant i just use the Rotellla T6 5w-30 as its avaialbe all over the place.
Do our cars take both 5w-30 or 5w-40 full synthetic or it doesnt really matter which weight to use.
Im in floirda and it gets hot here.
