Left tail lights staying lit
First,
could it be a fuse causing this and if so which fuse box and which fuse do I check? If not the fuse, what else? Thanks for reading.
Last edited by schmad1962; Aug 12, 2021 at 07:43 PM. Reason: Forgot to add something.
You must access the rear SAM which is on the floor of the spare tire area and see if there is any water intrusion.
Even if there is no visible intrusion, with the key out of the ing. you must remove the SAM and remove the two plastic covers and see if there is corrosion.
Last edited by schmad1962; Aug 14, 2021 at 11:26 AM. Reason: Forgot to add something.
when I turn the lights off whether the vehicle is started or not the right bulb goes off as it should and the left bulb stays lit for 20 seconds then goes out. If I open a door or I open the latch, the left light will light again and then when I close the door or the lift gate the bulb will then again stay lit for 20 seconds then go out. Is this some kind of warning light for something else or do I need to replace something? I have a video but the site won't let me upload it.
You were right, there was corrosion yet again in the SAM board (see picture), I cleaned it again and that seemed to correct the "staying on and hot bulb problem" although the outer left tail lamp still does not light. I don't know how many more cleanings this board can take as the green part of the circuit board is starting to wear. So I sprayed liquid rubber onto that section and it did not seem to cause any harm and it should insulate and protect it. I am wondering if I should just spray the whole board with liquid rubber at this point to protect it in the future, could that cause issues? Otherwise, do you know of how I should protect the box from further moisture, I have already sealed the right tail light lens but obviously water is still getting in from somewhere else. Or maybe just position the box in a way that the water does not travel down the wires? Any ideas? Thank you very much.
On my vehicle, the right front turn indicator was always on. I removed the SAM from under the right front seat and found corrosion. I removed the board from the black container and cleaned it with 91% isopropyl alcohol to remove the corrosion. Then reassembled and reinstalled into the vehicle.
The issue has not returned in the 2+ years since I performed the repair.
I would at least try this before you source a replacement.
About the main topic. I am not an electrical guru but I have worked on some of them. Looks like a short circuit to me which your pictures of the rear SAM backs up the finding.
