Change Battery with Bigger amper
______________
Hello,
I have ML350 4matic 2007 - it has webasto heater (aftermarket) and in my country winter weather conditions are about -25 celcilius. My car parked outside and unfortunatly my battery get empty sometimes. (because when webasto working, fan blower also works about 1hour)
I have also have 110ah varta is good condition.
it's 4cm bigger than 95ah. Can it fit the place? if it fits, Does it cause problems with the battery system of the car? Will it break the alternator/generator? Do I need to make any adjustments with Xentry? Thank You.
i have founded
- Model: KOZAK KO1100
- Pojemność: 110Ah
- Prąd rozruchowy [SAE]: 1000A
- Prąd rozruchowy [EN]: 940A
- Biegunowość: Prawy +
- Wymiary (dł x szer x wys): 353x175x190
A battery is charged at a maximum of 10% capacity per hour. The alternator will do this easily.
(PS: i have 110ah varta battery, i will not buy new one. Present battery is low quality russian brand 90ah)
I gave my car to dry cleaning yesterday, everything was dismantled and I took the opportunity to replace the battery, but I could not succeed.
95ah battery is 34cm, 110amper is 38cm long.
The distance between the battery fixing screws and the corner is 36 cm. (look 2nd photo)
If I put the battery in this shape, it would stand inclined. And at the same time, I couldn't insert it at an angle, instead, it was necessary to insert it vertically from the top because the area is almost 39-40 cm. (bad english sorry)
Small one is 100ah (95ah), bigger 110ah
Fixing Nuts
Putting vertically also hard.
bonus
