Brake Rotor Screws - ML500
Old Mar 12, 2022 | 11:31 PM
anavabi's Avatar
2006 ML500, 2008 ML350
Are these a must? I had to literally chip one off on the front left rotor. It was rust welded. Now I cannot replace the screw as the hole on hub is totally ruined. As the lug bolts ultimately hold the rotor in place, I was thinking I just go without one on this rotor.
Any thoughts will be appreciated.
Old Mar 13, 2022 | 06:44 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
What do you mean by.......I had to literally chip one off ?
Post a photo of this disaster.
Old Mar 13, 2022 | 09:22 AM
chassis's Avatar
2017 GLE350 4MATIC
Can you re-tap the hub hole?
Can you heli-coil the hub hole?
Old Mar 13, 2022 | 11:07 AM
anavabi's Avatar
The head of screw was taken off bit by bit. Screw is of very hard steel.
Old Mar 13, 2022 | 11:09 AM
anavabi's Avatar
I can. But I want to know if I can get away with not doing it. It takes a lot of time and work in my tiny garage.
Old Mar 17, 2022 | 10:04 PM
expl0rer's Avatar
GL550 X164
have you tried heat? Usually my go-to for broken bolts when I try to back them out. ​​​​​​​​​​​​​​You are the one who makes the decision and my post is not a recommendation. Personally I would not worry about the retaining screw. The lug bolts are doing the real work keeping things together and in place.
Old Mar 18, 2022 | 08:56 AM
anavabi's Avatar
Originally Posted by expl0rer
have you tried heat? Usually my go-to for broken bolts when I try to back them out. ​​​​​​​You are the one who makes the decision and my post is not a recommendation. Personally I would not worry about the retaining screw. The lug bolts are doing the real work keeping things together and in place.
Thank you.
Old Mar 20, 2022 | 10:42 PM
lkchris's Avatar
'10 CL550, '12 GL550
When you tighten that little screw, the holes in the rotor hub are centered over the threaded holes in the wheel hub. Both the hole in the rotor and the screw head contact surface are tapered. There is no reason to assume the same thing occurs when you tighten lug bolts, as nothing about that process moves the rotor … or moves it with accuracy.
it’s only wishful thinking to consider the notion there exist non necessary parts.
In fact, Mercedes specifies the screw be replaced with a new one every time it’s removed. That’s because it is provided with preapplied thread locking compound. That’s a clue it shouldn’t loosen … or be omitted.
