2008 ML350 Audio Volume Knob
2006 ML500, 2008 ML350
The volume knob is no longer working. The volume button on the steering wheel has to be pushed to change volume. Can this be repaired or I just have to live with this nuisance.
Your insights will be appreciated.
Thanks Major. My bad not to have been clear. This button works fine. The volume control knob on the radio, that I called knob, is not working. It turns on & off but the volume control component of it doesn't work at all.
Sorry for this.
Sorry for this.
Hi Major,
Could it possibly be the amplifier under the driver's seat, as one video suggested? To me, as the volume buttons on the steering wheel are functioning properly, it could not be the amplifier.
2002 ML 320 & 2006 ML500
2006 ML320 CDI (2 of) and 2008 GL320
I had this 06 ML. If I disconnect battery and reconnect it worked for a month or 2 then would do it again. Could not change stations either except with steering wheel buttons
. Weirdly I swapped head unit into another car 08GL and worked fine. Ended putting it back into original car but swapped the phone puck with other car. Everything works now. doesn’t seem logical to be tied up with puck but was in my case
anavabi (04-18-2022)
Everything else works perfectly. The battery was disconnected. The phone puck was disconnected.
I did a scan and this is what I got, I can't make any sense out it. Except this issue, I don't have any other problem at all. This car has been really good over the years. I don't know why I get so many fault codes.
Fault Codes(1):AGW-Audio gateway (MOST network management, diagnosis gateway, radio tuner)
D103 MOST component at position 3 reports open ring. Stored
Fault Codes(6):SDAR-Satellite radio
D000 Control unit N87/5 (SDAR control unit) is defective. Not checked
D001 Watchdog error : The control unit has been reset due to an internal error. Not defined
D004 The control unit was switched off due to excessive temperature (MOST transmitter and receiver unit). Not
defined
D011 The supply voltage of the control unit is too high (overvoltage). Not defined
D241 The antenna cable from component N87/5 (SDAR control unit) to component A2/93a5 (SDAR antenna) has an
open circuit. Not defined
D242 The antenna cable from component N87/5 (SDAR control unit) to component A2/93a5 (SDAR antenna) has a
short circuit. Not defined
defined
The radio changed in 08 for facelift. Mine are up to early 08. It might be worthwhile buying a used radio (of same type) as Lots of people upgrade and sell the original cheap. Simple to change. Youtubes on it. Not sure if later one can be changed without coding. Early one just needs car to have had same options. Camera etc.
Showbox jiofi.local.html tplinklogin
not sure how they work on the ML but if its a potentiometer based for example then they can wear out over time or get crap on the track that stops them working properly, not sure how accessible it would be to clean, if you can access it maybe worth a shot as could be a quick fix. if not I think you may be looking for a replacement
I had same problem this week. Easy fix, just pull the volume control knob outwards carefully , comes of quite easy. Consists of 2 main parts with a third fixed in second part, easy to put back too. Just clean inside where it came out with soft cloth and spray with electronic cleaner. Al clean and so spray removed parts. Push back and in and works 100% again!
Great info on this Spyker. I've noticed recently that the volume control knob on my 2009 ML350 4matic has begun to not change the volume as efficiently as in the past. I have to "slowly" turn it to affect the volume but the button on the steering wheel works just fine. When I next get a moment, I'll try your fix and report back. Thanks!
