ML350 2010 bluetec
Talal Al Hadidi (05-24-2022)
ML350 bluetec 2010. W164
2002 ML 320 & 2006 ML500
Sometimes, the Intake manifolds should be replaced, as those could be the reason for a defective M55...and if you remove Turbo, Intakes, etc than is your best chance to change the oil cooler...as this always has leakage.
I checked the wiring & changed the actuator
and still read the same fault
how can I check the wiring correctly?
thanks
I just changed the engine before 5 months with new manifold swirl runners
