Hydraulic Fluid LEAK in Steering rack W164
I have an ml280cdi and it has a leak right through the axis that comes out vertically from a cylinder coupled to the steering rack (I think it's called distributor head). See A in picture
When removing the bar, I removed a plastic cap that the head carries, and you can see perfectly how liquid oozes between the shaft and the body of the part. I include a picture with the leak.
I've looked at the WIS, but I'm a bit lost. It says how to remove the complete "distributor head" from the steering rack, but I don't see anything about disassembling the distributor head to change a seal -which I imagine will go on the top of the head- where the shaft attaches to the steering rod that goes to the steering wheel.
Does any one know's how to repair this leak without purchasing a new "distributor head - part B" ?
Any help???
It will be appreciated!
Bad news!!!! Also the rack? this is a hard and complicated labor issue. Front axis must be removed.I'm going to try Xenum XP100. It says that stops leaks in steering parts.
I think Ebay usa had the seal listed. Should be replaceable.
I think I'm going to test this. The problem is already there, so I won't loose too much.
Product specifications at:
https://lucasoil.com/products/proble...ring-stop-leak
