Tip: Clean you MAF sensors
Today I cleaned both my MAF sensors with special MAF cleaner and replaced both air filters.
Result:
Amazing how much filth was accumulated on those sensors
MAFcleaner
Result:
- Significant better MPG
- Much better respons and better acceleration
- I have to wait to see if the car does its regeneration less often
MAFcleaner
2013 ML350 Bluetec
If your air filters were clogged, I'd say that is where your mileage and acceleration increase came from. My Dmax LOVES a clean air filter, almost as it loves cold dense winter air.
Actually the old air filters were still clean, almost new, I have no cue when the previous owner replaced them but seems recent,
The MAF sensors at the other hand were pretty filthy like there was an hardened out oil film on them. I am pretty convinced the cleaning did the trick.
rapidoxidation (05-29-2024)
Originally Posted by Vmaxxer;[url=tel:8977939
8977939[/url]]Today I cleaned both my MAF sensors with special MAF cleaner and replaced both air filters.
Result:
MAFcleaner
Result:
MAFcleaner
Received 2,837 Likes
PFL205.064 with M276.823 (Oil pump solenoid defeated)
Originally Posted by W205C43PFL;[url=tel:8978302
8978302[/url]]Is there a risk of damaging it in the process?
And when you put it all back together, be sure it all properly seals up or else you’ll get a check engine light. But it’s all common sense.
Vmaxxer (05-31-2024)
I found it easier to screw in the air filter housing as the last part during install,
Joshinator99 (05-31-2024)
Use proper MAF cleaner (CRC makes one) and spray the MAF element in a way where the fluid & gunk drips off (and not into the electronics lol). Taking care is the order of the day.
